1 Reply Latest reply on Aug 10, 2013 5:12 AM by Mike M
    Lenova Ideapad Yoga 11
    Iamasurvivor
      Hello
      I need to be able to run Adobe Flash Player on the Lenova Ideapad Yoga 11, is there anyway to do this?
        • 1. Re: Lenova Ideapad Yoga 11
          Mike M Level 6
          Your Ideapad should have Windows 8 which HAS Flash Player embedded (for IE 10). Windows update SHOULD update FP and it SHOULD be enabled by default. If not:
          1. Launch Internet Explorer and navigate to http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
          2. If you see an animation playing, then Flash Player is enabled.
          3. If you don’t see an animation playing, then Flash Player is not enabled. In that case, click on the Tools icon in the top right corner of Internet Explorer. (The icon looks like a cogwheel.)
          4. In the drop-down menu which appears, click Manage Add-Ons.
          5. In the dialog which appears, select Toolbars and Extensions.
          6. In the list of Add-ons, look for “Shockwave Flash Object” – which is another name for Flash Player.
          7. In the Status column, check to see whether Shockwave Flash Object is Disabled. If it is, click the row for Shockwave Flash Object to highlight it.
          8. In the bottom right corner of the Manage Add-ons dialog, click the Enable button.
          9. Close the Manage Add-ons dialog.
          10. Click Refresh to reload the webpage. If you see the animation playing this time, then Flash Player has been successfully enabled.
          If you continue to encounter problems viewing Flash content after completing these steps, please see our FAQ on ActiveX filtering.
          ActiveX Filtering in Internet Explorer
