2 Replies Latest reply on Aug 12, 2013 5:29 AM by BEGINNER_X
    Find and Replace
    BEGINNER_X Level 3
      Hi All,
      Very very simple request for you...
      But I am strugling:
      //Need output from the below coding
      var myPstyles = myDoc.allParagraphStyles;
      var myAllPStyles = new Array();
      for(i=2; i<myPstyles.length; i++)
        var myParaName = myPstyles[i].name;
        myAllPStyles.push(myParaName)
        myAllPStyles.replace(/\,/, "\r")               //Please help in this line
        alert(myAllPStyles)
      ________________________________________________________________________________
      //Using this code I got output
      //var myParaStyles = myDoc.paragraphStyles.everyItem().name.join("\r");
       //alert(myParaStyles)
      Output I needed as per below screenshot:
      Thanks in advance
      Beginner
        • 1. Re: Find and Replace
          Mac_rk
          try this
          for(i=1; i<myPstyles.length; i++)
          var temp = myAllPStyles.toString().split(",")
          alert(temp.toString().replace (/\,/gi, "\r"))
          • 2. Re: Find and Replace
            BEGINNER_X Level 3
            Hi Mac,
            Thank for your valuable reply...
            I have small clarification in the below code. Could you explain to me.
            //var temp = myAllPStyles.toString().split(",")           //Without this line program run successfully
            alert(myAllPStyles.toString().replace (/\,/gi, "\r"))
            Could you please explain what is the use of split. Could you please guide me.
            Beginner
