1. Re: Slide gets a dull look at the end?
Lilybiri Aug 12, 2013 7:26 AM (in response to iBabs2)Which version are you using? Could you check if either the slide, or objects on the slide have a 'Fade out' transition?
2. Re: Slide gets a dull look at the end?
iBabs2 Aug 12, 2013 10:58 AM (in response to Lilybiri)Hello,
I am using captivate 5 and everything is set to fade in only?
any thoughts??
thanks
babs
4. Re: Slide gets a dull look at the end?
Lilybiri Aug 12, 2013 3:04 PM (in response to iBabs2)Sure there is no slide transition? I understand it is happening on each slide, not on start and end slide only, as Alistar is asking about?
5. Re: Slide gets a dull look at the end?
Alistar3050 Aug 12, 2013 5:11 PM (in response to Lilybiri)My mistake - I misread the question and thought it was only the final slide. Slide transitions is all I can suggest if it's happening on every slide.
6. Re: Slide gets a dull look at the end?
Jennifer Speer Aug 13, 2013 6:08 AM (in response to iBabs2)Try moving your click box end point back a few seconds from the end of your slide time. Obviously make sure it isn't cutting off any audio or anything, but try moving the end of the clickbox on the timeline back so it is not quite at the very end of the slide. This has solved this issue for me.
