1 Reply Latest reply on Aug 12, 2013 3:22 PM by Carl Von Stetten
    newcf Level 1
      my page can't find the css for fc if i included them within the header, but it found and wokred fine if i have them within cfinlude tag?
      <!--- <script type="text/javascript" src="js/showHide.js"></script>
      <link rel="stylesheet" type="text/css" href="css/style.css"/>--->
      <cfinclude template="js/showHide.js" >
      <cfinclude template="css/style.css" >
        • 1. Re: question?
          Carl Von Stetten Adobe Community Professional & MVP
          Is the "css" folder an actual folder right on the webroot?  Or do you have a ColdFusion mapping created for "css"?
          Normally, the web server (IIS, Apache, etc.) will serve the static resources like .css and .js files, as long as they are web-accessible.  ColdFusion doesn't even need to be involved.  However, if the files are not web-accessible (like in a folder above the web root or elsewhere), and ColdFusion is able to see them using a mapping, then you need to create is a virtual directory on your web server to point to the same place as your ColdFusion mapping.  Then your web server can serve up those resources.
          -Carl V.
