4 Replies Latest reply on Aug 23, 2013 8:02 AM by Esther_Pix
    Time
    Esther_Pix
      Hello all,
      I am trying to create a schedule based off one input field, I want to put in "text/time box 1" a time and time "text/time box 2" will automatically add 25 minutes to that etc...
      I am using 24 hour format ( I can switch but assume its easier that way.) and I will not be crossing the days,
      Thank you in advance for any help on this.
        • 1. Re: Time
          Esther_Pix Level 1
          Any Ideas?
          • 2. Re: Time
            mrfale67 Level 2
            Working solution by me (tested):
            var oCurrentDate = new Date (this.rawValue.replace("-", " ", "g"));
            var CurrYear = oCurrentDate.getFullYear(); // get 4 digit year number
            var CurrMonth = oCurrentDate.getMonth() + 1; // get current month number
            var CurrDay = oCurrentDate.getDate();
            if (CurrMonth.toString().length<2) {CurrMonth = '0' + CurrMonth;}
            if (CurrDay.toString().length<2) {CurrDay = '0' + CurrDay;}
            xfa.resolveNode("DateField1[1]").formattedValue = CurrDay + "/" + CurrMonth + "/" + CurrYear;
            code under DateField1[0] exit event
            Both date fields have this pattern: date{DD/MM/YYYY}
            in
            Validation Pattern... | Edit tab | Display tab | Validation tab
            You should adapt it from date to time.
            • 3. Re: Time
              mrfale67 Level 2
              This is more focused on your needs:
              var StartTime = this.rawValue.split(":");
              var oCurrentDate = new Date();
              oCurrentDate.setHours(StartTime[0]);
              oCurrentDate.setMinutes(StartTime[1]);
              var CurrHours = oCurrentDate.getHours(); // get 4 digit year number
              var enlapse = 5;
              var CurrMin = oCurrentDate.getMinutes() + enlapse; // get current month number
              if (CurrMin + enlapse > 60) {CurrHours++; CurrMin = CurrMin - 60;}
              if (CurrMin.toString().length<2) {CurrMin= '0' + CurrMin;}
              if (CurrHours.toString().length<2) {CurrHours = '0' + CurrHours;}
              xfa.resolveNode("TimeField2").formattedValue = CurrHours +  ":" + CurrMin;
              2 time fields
              code under TimeField1 exit event
              Both time fields have this pattern: time{HH:MM}
              in
              Set enlapse var to your needs.
              You'll probably have to add more checkpoints to handle wrong time format inputs in TimeField1.
              • 4. Re: Time
                Esther_Pix Level 1
                mrfale67,
                Thank you for your help, I'll give it a shot.
