1 Reply Latest reply on Aug 13, 2013 2:48 AM by areohbee
    Export Filter - processing in batches
    BigRedler Level 1
      I'm writing an export filter that uses an external tool to process the photos. The tool can/should be multithreaded and I want to take advantage of this by processing the images in groups of 2 or 4 or 8 (or whatever). This means that I gather the paths and the renditions to satisfy in a table and once the table reaches the desired size I process the images in the batch together, empty the table and continue.
      For some reason I can't make this work. To illustrate, I've reduced this problem to this scenario (Example A)
      1. While iterating filterContext:renditions() I copy the paths and renditionToSatisify to a table
      2. Iterate over the table of copies and process the images one by one.
      When running this, I'm getting this error:
      This plug-in’s post-processing task did not finish successfully.
      ?:0: attempt to index field 'exportSettings' (a nil value)
      It seems to me that LR doesn't like me to call "renditionIsDone" out of sequence but I don't know what to make of this.
      I'm also adding "Example B" to show that if I call processOne right after adding its entry to the table all is well.
      Example A
      function processOne(table)
           local commandResult
           commandResult = PluginManager.doit({table.a})
           if commandResult ~= 0 then
               table.b:renditionIsDone( false, "Image Processing Failed (" ..  commandResult .. ")")
           else
               table.b:renditionIsDone (true,"very good indeed")
           end
      end
      function JPEGminiFilterProvider.postProcessRenderedPhotos( functionContext, filterContext )
        local renditionOptions = {
        plugin = _PLUGIN,
        renditionsToSatisfy = filterContext.renditionsToSatisfy,
        filterSettings = function( renditionToSatisfy, exportSettings )
        end,
        local maxGroupSize = 1
        local groupSize = 0
        local group = {}
        for sourceRendition, renditionToSatisfy in filterContext:renditions( renditionOptions ) do
        local success, pathOrMessage = sourceRendition:waitForRender()
        if success then
        groupSize = groupSize + 1
        group[groupSize]={a=pathOrMessage, b=renditionToSatisfy}
        end
        end
        for i,v in ipairs(group) do
        processOne(v)
        end
      end
      Example B
               plugin = _PLUGIN,
               end,
           local groupSize = 0
           local group = {}
               if success then
                     processOne(group[groupSize])
               end
           end
      end
