3 Replies Latest reply on Aug 13, 2013 10:24 AM by Endoplasmic
    Call a function
    Ahoo110@gmail.com
      I am setting this function in my compositionready and I want to call it from different places. That works fine but I also want to run myFunction() when the program launches. So I have this: (and it is not working) what am I doing wrong?
      sym.getComposition().getStage().myFunction();
      sym.myFunction = function()
      alert("function called")
        • 1. Re: Call a function
          resdesign Adobe Community Professional & MVP
          Could you try this:
          function myFunction()
          In composition ready:
          function myFunction(){
          alert('this button uses myFunction');
          sym.$('Rectangle').click(function(){
          myFunction();
          • 2. Re: Call a function
            Ahoo110@gmail.com Level 1
            No it didn't work
            I get error if I don't setup the function like
            and since I want to call it from different symbols, then I add a sym. to it.
            How ever I can't call the function for some reason. I don't know what I am doing wrong.
            • 3. Re: Call a function
              Endoplasmic
              Welcome to the wonderful world of creationComplete being fired before compositionReady!
              Here is what I do:
              On your "Stage" in compositionReady  you have:
              sym.myFunction = function() {
                alert("function called");
              //this is where you want to look through the symbols on the stage and fire an onInit function if it's there
              var elements = sym.getChildSymbols();
              var total = elements.length;
              var i = 0;
              for(i; i < total; i++){
                if(typeof elements[i].onInit == 'function'){
                  elements[i].onInit();
              On your other symbol's creationComplete you have:
              sym.onInit = function() {
              The other option (which I'm just speculating) is to put your function in the creationComplete handler on the Stage object (that *should* get built first). I don't do that myself, but it's possible that it might just work!
