21 Replies Latest reply on Aug 20, 2013 10:25 AM by George_Johnson
    Check boxes / display
    AndyHopkins1965
      I have an order form that customer will fill in quantity of products, the forms totals and add $8 shipping if it is below $400.  There are 3 check boxes that the customer can check.  "Overnight" "2nd Day" and "International"
      Question:  How can I have the "Extra shipping" and 'Total" fields display "We'll Call" (or whatever words) if one of those check boxes has been checked?
      thanks
      Andy
      MacOS
      Acrobat X Pro
        • 1. Re: Check boxes / display
          MichaelN Level 3
          Hi Andy,
          Create a text field with "We'll Call" in it, then make it hidden (Text Filed Properties > General > Form Field Hidden).
          Then make this the mouse up script for the "Extra shipping" and "Total" checkboxes:
               // Get the value of the check box
               var v = getField("myCheckBox").value;
               //If it is off, then hide the text field
               if (v == "Off") {
               this.getField("myTextField").display= display.hidden;    //hide the text field
               else {
               this.getField("myTextField").display= display.visible;     //show the text field
          Replace "myCheckBox" with whatever the checkbox name is in your form.
          Replace "myTextField" with whatever the hidden text field name is in your form.
          I hope this helps.
          • 2. Re: Check boxes / display
            AndyHopkins1965 Level 1
            MichaelN,
            Thanks so much for taking the time to help.  Here's what I have in the "Mouse Up" -Run a Java Script field.  It's not working yet, do I have something wrong?
            var v = getField("overnight").value;
            var v = getField("second").value;
            var v = getField("international").value;
            //If it is off, hide the button
            if (v == "Off") {
            this.getField("WellCall").display= display.hidden;
            else {
            this.getField("WellCall").display= display.visible;
            • 3. Re: Check boxes / display
              MichaelN Level 3
              Hi Andy,
              You have assigend the same variable "v" to all 3 check boxes. They should have unique variable names.
              Use this as the mouse up action for the "WellCall" text field:
                   // Get the value of the overnight check box
                   var a = getField("overnight").value;
                   // Get the value of the second check box
                   var b = getField("second").value;
                   // Get the value of the international check box
                   var c = getField("international").value;
                   //make WellCall field visible if any of the check boxes are on
                   if (a == "On" || b == "On" || c == "On") {
                   //othewise make field hidden
                   else {
              • 4. Re: Check boxes / display
                Thanks again MichaelN,
                It still not working.  I really appreciate your help though.
                Andy
                • 5. Re: Check boxes / display
                  MichaelN Level 3
                  Open the JavaScript console in Acrobat and see exactly what the error message is when you test the form.
                  That will help in identifying the problem.
                  • 6. Re: Check boxes / display
                    Hey Michael
                    Here's all that comes up in the JS Console - Debugger
                    Acrobat EScript Built-in Functions Version 10.0
                    Acrobat SOAP 10.0
                    ReferenceError: getfield is not defined
                    3:Field:Calculate
                    3:Field:Calculate
                    TypeError: getField("subtotal") is null
                    4:Field:Calculate
                    4:Field:Calculate
                    4:Field:Calculate
                    I don't see anything about the script in question in there.   Thanks again.  Here's my email address if that makes it easier.  andy at andrewhopkins dot net
                    • 7. Re: Check boxes / display
                      MichaelN Level 3
                      I think these errors mean that the names of the fields on your form do not match the names in the script.
                      Make sure you:
                      • Replace "myCheckBox" with whatever the checkbox name is in your form.
                      • Replace "myTextField" with whatever the hidden text field name is in your form.
                      Javascript is case sensitive, so the names in the script must match exactly with whatever the field names are on the form.
                      • 8. Re: Check boxes / display
                        George_Johnson MVP & Adobe Community Professional
                        The correct name of the method is "getField", not "getfield".
                        • 9. Re: Check boxes / display
                          Yep, they all match the names of the CheckBox and TextField.  I'm stumped.  Thanks again for the help.
                          • 10. Re: Check boxes / display
                            Perhaps you can copy/paste back your script as it currently stands. After making sure it doesn't use "getfield" anywhere.
                            • 11. Re: Check boxes / display
                              Note that the "getfield" error may be in a different script than the one you're working with. It's being reported as an error in a calculation script of one of the fields.
                              • 12. Re: Check boxes / display
                                Will do George.  I'll go through and locate those typos.
                                thanks
                                A
                                • 13. Re: Check boxes / display
                                  How do I find these errors to fix them?  I think I've looked at all the fields that have a script and i can't seem to find them.
                                  Acrobat SOAP 10.0
                                  3:Field:Calculate
                                  3:Field:Calculate
                                  4:Field:Calculate
                                  4:Field:Calculate
                                  4:Field:Calculate
                                  • 14. Re: Check boxes / display
                                    Acrobat lets you edit all JavaScripts at once (look under the JavaScript panel), so you can activate that and search for occurrences of "getfield" and "subtotal" and you will see which fields are affected.
                                    • 15. Re: Check boxes / display
                                      MichaelN Level 3
                                      Also the number 3 or 4 in the error message tells you the line number of the error, which sometimes helps find it.
                                      • 16. Re: Check boxes / display
                                        Thanks so much Michael and George.  I have gone through every field, (I think) and can't find the errors.  I'm stumped.  Somehow I managed to add more?!  Here's the current list on debugger.
                                        Acrobat SOAP 10.0
                                        3:Field:Calculate
                                        3:Field:Calculate
                                        4:Field:Calculate
                                        4:Field:Calculate
                                        4:Field:Calculate
                                        TypeError: f is null
                                        • 17. Re: Check boxes / display
                                          Did you use the "Edit All JavaScripts" feature as suggested earlier?
                                          • 18. Re: Check boxes / display
                                            Also the "f is null" error is often the result of using one of the built-in calculation methods and one or more of the fields that you specified when setting it up have been renamed or deleted, so it's attempting to use a field that no longer exists.
                                            • 19. Re: Check boxes / display
                                              I tried, but it would let me change anything.  (wasn't sure what I was looking for though)  Here's an example of what I see.
                                              /*********** belongs to: AcroForm:Tot8:Validate ***********/
                                              if (event.value==0) event.value="";
                                              //</ACRO_script>
                                              //</AcroForm>
                                              //<AcroForm>
                                              //<ACRO_source>Tot9:Validate</ACRO_source>
                                              //<ACRO_script>
                                              I tried to Tot9 to Tot8 so they would agree, but it won't change.
                                              • 20. Re: Check boxes / display
                                                I went through and redid each of the calculations.  I might just start over with the fields in question.
                                                • 21. Re: Check boxes / display
                                                  I actually don't like to change anything when lookiing at all of the scripts that way, but you should be able to do a seach and identify which fields are causing the error, by looking for "getfield" and "subtotal". Once you've identified the fields, you can edit the calculation scripts as you normally would.
