0 Replies Latest reply on Aug 13, 2013 11:04 AM by BNYPGH
    Flash Silent Autoupdate failing
    BNYPGH
      Trying to get silent autoupdates to work for flashplayer.
      Currently I'mw orking with version 11.7.7.202, trying to get it to update to latest version from adobe.  I do not have an internal web server setup for updates.
      Here is my mms.cfg file settings:
      AutoUpdateDisable=0
      SilentAutoUpdate=1
      AutoUpdateInterval=1
      SilentAutoUpdateVerboseLogging=1
      When I run the task manually I get the following error codes in the log file:
      2013-8-13+17-2-59.525 [info] 1614
      2013-8-13+17-2-59.572 [info] 1616
      2013-8-13+17-2-59.572 [info] 1618
      2013-8-13+17-2-59.603 [info] 1619 1063
      2013-8-13+17-2-59.728 [info] 1614
      2013-8-13+17-2-59.728 [info] 1616
      2013-8-13+17-2-59.728 [info] 1618
      2013-8-13+17-2-59.853 [info] 1608
      2013-8-13+17-2-59.868 [info] 1612
      2013-8-13+17-2-59.868 [info] 1620
      2013-8-13+17-2-59.900 [info] 1604
      The task is running as system, and the pc I am trying to update is on a proxy server, or actually an automatic configuaration script or .pac file
      When I manually run FlashPlayerUpdateService.exe, it opens and clsoes quickly and then the following info is written to log file:
      Is there somewhere I can look up these error codes to see why its failing.  I've been researching this for a few days and the suggestions I've tried from other posts haven't helped.
