4 Replies Latest reply on Aug 15, 2013 10:29 AM by mauritsbrock
    Selecting multiple layers and merge
    mauritsbrock Level 1
      is it possible to select multiple layers (with layermask) and merge them?
      tell application "Adobe Photoshop CS6"
          tell current document
              set current layer to every layer of layer set "bloem 1-9" of layer set "Bloem"
              tell current layer
                  merge
              end tell
          end tell
      end tell
        • 1. Re: Selecting multiple layers and merge
          Michael L Hale Level 5
          Not sure how to do this in Applescript but I understand that Applescript has a do Javascript command so this might help.
          With javascript you don't have to select all the layers in a set. You just select the layerSet and merge.
          app.activeDocument.activeLayer.merge(),
          • 2. Re: Selecting multiple layers and merge
            Thanks Michael,
            it works great but the problem is that i lose the folder of the layers. Is it posible to merge the layers within the folder and keeping the folder?
            Maurits
            • 3. Re: Selecting multiple layers and merge
              Yes, for that you have to select the layers that are in the set. Here is one way using javascript
              function selectLayerBelow( add ){
                  var desc = new ActionDescriptor();
                      var ref = new ActionReference();
                      ref.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Bckw" ) );
                  desc.putReference( charIDToTypeID( "null" ), ref );
                  if(add!=undefined && add = true )desc.putEnumerated( stringIDToTypeID('selectionModifier'), stringIDToTypeID('selectionModifierType'), stringIDToTypeID('addToSelectionContinuous') );
                  desc.putBoolean( charIDToTypeID( "MkVs" ), false );
                  executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
              // assumes a layerSet the the activeLayer and doesn't work correctly if there are nested layerSets
              var numberOfLayersInSet = app.activeDocument.activeLayer.layers.length;
              selectLayerBelow();
              for(var layerIndex = 1;layerIndex<numberOfLayersInSet;layerIndex++){
                  selectLayerBelow( true );
              app.activeDocument.activeLayer.merge();
              • 4. Re: Selecting multiple layers and merge
                Thank you Michael!
