This content has been marked as final.
Show 4 replies
1. Re: How can I shift a text box over with keyframes while keeping the keyframes the same?
aronbothman Aug 16, 2013 2:16 PM (in response to iceraven721)Hi! Can you specify what program you're using? After Effects, Flash, Premiere, ...?
2. Re: How can I shift a text box over with keyframes while keeping the keyframes the same?
iceraven721 Aug 16, 2013 2:20 PM (in response to aronbothman)After Effects.
3. Re: How can I shift a text box over with keyframes while keeping the keyframes the same?
iceraven721 Aug 18, 2013 9:03 PM (in response to aronbothman)After Effects.
4. Re: How can I shift a text box over with keyframes while keeping the keyframes the same?
aronbothman Aug 19, 2013 12:53 PM (in response to iceraven721)If I am understanding your question correctly, you should:
1. On the timeline, select all the keyframes that you want to affect (so that they're higlighted yellow)
2. Make sure the slider is parked over one of the keyframes
3. Change the value of whatever property you are working with (it sounds like in this case it would be position). The same change should be applied to all highlighted keyframes.
