0 Replies Latest reply on Aug 13, 2013 2:00 PM by LioCanada
    AI CS 6 crashes when I try to export  an image with layers to PS CS6
    LioCanada
      Hi guys!
      well, I'm completely newbie on Illustrator. I only have to use it to create level on pdf images to work with it in Photoshop.
      So I installed Illustrator yesterday for the first time and immediately the problems started.
      Ay the first opening I had more than one error
      Immediately following this (before the program started for its first time)
      Then I opened a pdf file in it, select > all , Object >  clipping mask > release, Layers, release to layers (Sequence).
      Till here all went OK.
      At this point All i nedd it's to export in Photoshop CS6.
      So File > export >save as *psd.
      At this point Illustrator crashes every time!
      I did all the update with Adobe Application Updater, my PC is new and a really good PC.
      It runs Win8 64 and with PS all goes like a charme.
      What have I to do? I see many posts about the plugins problem (and still no solution by Adobe).
      I ignore the problem for the plugin errors, and after some reload now I don't have that error but this one:
      Same thing when I relaunch, each time and every time.
      I need to solve this problem and it's impossible for me to call Adobe customer assistence As you can see my English is pretty bad and I can write but not speak by phone.
      Can you guys hep me please?
      Thanks in advance
      Lio
