3 Replies Latest reply on Aug 15, 2013 6:49 AM by p.sim
    cfloop - cfoutput bewilderment
    Leonard B Level 2
      Hello.
      Versions:
      CF8, MySQL
      I have one individual who fills the MSO postion for two different departments. I need to search a DB Table of submitted reports and return all submitted reports the MSO is associated with. Nine for dept-01 and four for dept-02. When I output the results as a text list, all displays as intended with no grouping or separations. However, when I cfloop the output, over a <cfselect> the results are grouped and two separate <cfselect> boxes are created. Dept-01 individuals in first one and dept-02 are displayed in second, each with their own submit button.
      What am I missing/doing wrong? How would I accomplish the output so there is only one <cfselect> containing all nine names to choose from?
      Below is what I have at the moment.
      This query below obtains agency_cert_number for each agency and MSO is associated with. In this case it will return two departments.
      <cfquery name="rsCheckMSO" datasource="DSN">
        SELECT
          individual_records.last_name,
          individual_records.first_name,
          individual_records.cert_number,
          individual_records.agency_cert_number,
          county_agencies.org_name
        FROM
          individual_records
        INNER JOIN
          county_agencies ON individual_records.agency_cert_number = county_agencies.agency_cert_number
        WHERE
          individual_records.cert_number = <cfqueryparam value="ES60043003" cfsqltype="cf_sql_varchar">
      </cfquery>
      <cfoutput>
      Dept - 01 agency_cert_number > ES00000639
      Dept - 02 agency_cert_number > ES00000643
      </cfoutput>
      I then cfloop through the reports to get all records associated with the two above agency_cert_numbers
      <cfloop query="rsCheckMSO">
      <cfquery name="rsAirwayReports" datasource="snocountyemssql01">
      SELECT DISTINCT ParamedicName, ParamedicCertNumber
      FROM airway_management_reports
      WHERE AgencyCertNumber = <cfqueryparam value="#rsCheckMSO.agency_cert_number#" cfsqltype="cf_sql_varchar">
      ORDER BY ParamedicName
      </cfquery>
      <cfquery name="rsAirwayReports" returns Nine records (Dept-01=5, Dept-02=4).
      --- Output 1 ---
      This displays a list of Paramedics who have submitted reports. The list is display in ASC order with no grouping/separation between names.
      <cfoutput query="rsAirwayReports">
      #ParamedicName#, #ParamedicCertNumber#<br />
      </cfoutput>
      --- Output 2 ---
      This displays two <cfselects> listing all the names grouped by associated department. Five for dept-01 and 4 for dept-02
      <cfform action="#cgi.script_name#" method="post" enctype="multipart/form-data" name="Test-01" id="Form-01" lang="en" dir="ltr">
      <label>Paramedic</label>
      <cfselect name="Paramedic" size="1" id="Paramedic" dir="ltr" lang="en">
      <option value="None" selected="selected">- Select Paramedic -</option>
      <option value="#ParamedicCertNumber#">#ParamedicName#</option>
      </cfoutput>
      </cfselect>
      <cfinput type="submit" name="ButtonDisplay" id="ButtonDisplay" dir="ltr" lang="en" value="DISPLAY">
      </cfform>
      </cfloop>
      TIA for insights and suggestions.
      Leonard B
        • 1. Re: cfloop - cfoutput bewilderment
          p.sim
          You don't need a loop, but you need IN in your rsAirwayReports. Here's the code:
                    SELECT DISTINCT ParamedicName, ParamedicCertNumber, AgencyCertNumber
                    WHERE AgencyCertNumber IN (<cfqueryparam value="#ValueList(rsCheckMSO.agency_cert_number)#" list="true" cfsqltype="cf_sql_varchar">)
          </cfquery>
          <cfoutput query="rsAirwayReports" group="AgencyCertNumber">
                    #AgencyCertNumber#<br />
                    <cfoutput>
                    </cfoutput>
          </cfoutput>
                              </cfoutput>
                    </cfselect>
          </cfform>
          • 2. Re: cfloop - cfoutput bewilderment
            p.sim Level 3
            Antoher thing that you could improve is to group the options.
            http://www.w3schools.com/tags/tag_optgroup.asp
            • 3. Re: cfloop - cfoutput bewilderment
              p.sim Level 3
              Use standard HTML form tag if you are not planning taking advantages of cfform. Also, enctype="multipart/form-data" usually is a form for submitting attachment.
