1. Re: Problem with forms
Lucia LaoAug 14, 2013 10:20 AM (in response to gustav_242)
Did you manually insert the pagebrake in "Page View". In FormsCentral Design tab, with the form in editing mode, go to app menu View/Page View. Once you switched to Page View, you can insert pagebreak in your form. Did you use one of our templage, if so, which form template did you use and where did you add the pagebreak?
Hope this helps, if not, please share the form to llao@adobe.com and I can take a look.
Lucia
2. Re: Problem with forms
Genevieve LarocheAug 14, 2013 10:23 AM (in response to gustav_242)
First, if you want to edit the page layout of the PDF form make sure that you are in "Page View". You can switch the views in the Design Tab from either the "View" button in the bottom right corner of FormsCentral or under the "View" menu in the top right.
Page Breaks are specific to their view. This mean that if you add or remove a Page Break in the Web View it will only affect the online web (html) form. If you add or remove a Page Break in the Page View it will only affect the PDF form.
I'm not sure what you mean by "maintain configuration" can you elaborate on that?
Hope this helps
Gen
3. Re: Problem with forms
gustav_242 Aug 14, 2013 10:45 AM (in response to Genevieve Laroche)hello!
sorry for my explanation, i try to be clear:
i have a system that run with .asp, it put the data of each input field (in html) in pdf template with same inputs and create a new pdf with data inserted.
So, when i open this new pdf with data inserted in inputs i can visualize the data in each input, only when the pdf is in one page.
But, when i crop in various pages (for example 3 pages) only the first page i can visualize the data in each input, in pages 2 and 3 not.
Or an strange behaviour: I can visualize the data only when i click (with mouse) in input field (change the background colour).
Thanks Again, and sorry if my english is poor.
Gustav.
4. Re: Problem with forms
Lucia LaoAug 16, 2013 2:55 PM (in response to gustav_242)
Thank you for the additional information. I have a few questions:
Which tools are you using to generate the PDF template and also the new PDF with data inserted? Are you using FormsCentral in your workflow?
Please attach or email to llao@adobe.com
-screenshoots that illustrate the problems/issues.
-if possible, the actual pdf template and the generated pdf with data inserted
In the meantime, let me point you to the Acrobat / Livecycle forums if you are using these tools
http://forums.adobe.com/community/acrobat
http://forums.adobe.com/community/livecycle
Lucia
5. Re: Problem with forms
Lucia LaoAug 15, 2013 6:33 PM (in response to Lucia Lao)
1 person found this helpfulHi,
Thank you for sending the screenshots and additional details.
Please see this link http://forums.adobe.com/docs/DOC-3661 on how to make a PDF form created with FormsCentral editable in Acrobat.
Lucia
