3 Replies Latest reply on Jan 16, 2008 3:05 PM by TOdd_23523523
    e4x troubles with namespaces
    TOdd_23523523 Level 1
      Hello All,
      I've been trying to do something that I've considered very basic..and I've been banging my head over it for awhile so I thought I'd throw this out for you gurus...
      I'm trying to select a node from xml where a child has a specific value
      For example:
      var xml:XML =
      <communication xmlns="stuffHERE">
      <folder>
      <id>1</id>
      <folder>
      <id>2</id>
      </folder>
      <folder>
      <id>3</id>
      <folder>
      <id>4</id>
      </folder>
      </folder>
      </folder>
      In the above, I'm using an e4x expression that looks like:
      xml..folder.(id == 3)
      All works well when I don't have a namespace declared.
      When I have a name space declared, I keep getting nothing back.
      I'm using the namespace test="http..."
      use namespace test
      Any ideas on what I'm doing wrong? BTW, I've tried many, many different e4x expressions, none that work.
      Also, any techniques for debugging e4x? I've already included some dynamic e4x expression parsers that I found on the web. But I find that while I can get the expression to work fine dynamically, it still doesn't work.
      Here's my test MXML file, sorry for how ugly it looks in this window., I"m hoping you can just copy this and paste it into a new MXML file for you to look at...:
      [I'm posting the MXML on the next post to this question]
        • 1. e4x troubles with namespaces
          see next msg for code
          • 2. Re: e4x troubles with namespaces
            This code Might work better:
            <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="horizontal">
            <mx:Script>
            <![CDATA[
            import mx.logging.targets.TraceTarget;
            import com.theriabook.util.logging.TraceLogOutput;
            private var comm:XML =
            <CommunicationHierarchy xmlns=" http://www.directTestmarketing.com/ws/schemas/communicationHierarchyService">
            <folder>
            <id>13</id>
            <recordType>FOLDER</recordType>
            <iconId>icon id</iconId>
            <label>label</label>
            <shortDescription>short description</shortDescription>
            <description>Folder 21 description</description>
            <externalId>1</externalId>
            <template>
            <id>21</id>
            <recordType>TEMPLATE</recordType>
            <description>Template 22 description</description>
            </template>
            <folder>
            <id>14</id>
            <description>Folder 31 description</description>
            <link>
            <id>13</id>
            <label>link label</label>
            <url>link url</url>
            <description>description of link - 14</description>
            </link>
            </folder>
            <folder>
            <id>15</id>
            <description>Folder 36 description</description>
            <link>
            <id>15</id>
            <url>link url</url>
            <description>description of link - 16</description>
            </link>
            </folder>
            <link>
            <id>8</id>
            <url>link url</url>
            <description>description of link - 9</description>
            </link>
            <link>
            <id>12</id>
            <url>link url</url>
            <description>description of link - 13</description>
            </link>
            </folder>
            <template>
            <id>44</id>
            <description>Template 45 description</description>
            </template>
            <template>
            <id>45</id>
            <description>Template 46 description</description>
            </template>
            </CommunicationHierarchy>
            private namespace directTest = " http://www.directTestmarketing.com/ws/schemas/communicationHierarchyService";
            use namespace directTest;
            public var directTest2:Namespace = new Namespace(" http://www.directTestmarketing.com/ws/schemas/communicationHierarchyService");
            private function onGoClick(e:MouseEvent):void
            var xml:XML = new XML(inputXML.text);
            // All these filters didn't work:
            // new XMLList(xml..folder.(id ==13));
            // new XMLList(xml..folder.("id" =="13"));
            // These Worked:
            // new XMLList(xml.folder[0])
            // new XMLList(xml..folder.(id == 13));
            // new XMLList(xml.descendants("folder").(id == 13));
            //var filterdXML:XMLList = new XMLList(directTest2::folder.(id == 13));
            var filterdXML:XMLList = new XMLList(xml.descendants("folder").(id == 13));
            outputXML.text = filterdXML.toXMLString();
            </mx:Script>
            <mx:TraceTarget level="0" />
            <mx:TextArea id="inputXML" width="100%" height="100%" text="{comm.toXMLString()}"/>
            <mx:Button id="go" click="onGoClick(event)" />
            <mx:TextArea id="outputXML" width="100%" height="100%" />
            </mx:Application>
            • 3. Re: e4x troubles with namespaces
              It seems that if in the XML I add a prefix to the namespace that things work.
              FOr example, if I make that top node look like:
              <CommunicationHierarchy xmlns:nx=" http://www.directTestmarketing.com/ws/schemas/communicationHierarchyService">
              <folder>
              Then all works as planned. The question I then have, is if someone could eloquently explain to me why having a default namespace breaks everything...
