3 Replies Latest reply on Aug 14, 2013 11:32 AM by ic3man7019
    How do you draw an arrow-shaped end on the end on a rectangle using lines?
    ic3man7019 Level 1
      I need to know how to draw a pointed end on a rectangle. The end should look like a greater-than sign. Do I just need to use lines to draw the rectantgle, then create a graphic and set the path attribute to the appropriate value? I have no idea how to structure this. Any help is greatly appreciated. Again, the end of the rectangle should look like this: > . Maybe using lines to draw a rectangle is the wrong approach... Please correct me if I'm going about this all wrong.
