3 Replies Latest reply on Aug 16, 2013 6:48 AM by gkaiseril
    When I add page number pagination through Javascript to my PDF, the printed version produces squares
    oddish69 Level 1
      Hello. I am applying a page number to a combined PDF in the format of: 1/42, 2/42, 3/42 and so on.
      I am doing this through a module in access and running a macro to run it. The code is below. Here is the problem: When that is applied, the PDF looks perfect in document view in acrobat. When I print the PDF out on [U]any[/U] printer, around 75% of the text/numbers are replaced by square characters and/or hieroglyphic type characters. (Mostly squares).
      Here's the catch, when I take the pagination out, and the PDF does not have any page numbers....it prints perfectly with no squares. I feel as though this script is defaulting the font to Helvetica, which is has custom encoding and is not embed within the document when the character pdf is produced. (If that makes sense?)
      Is there any problem with this script? I've used this script in the past. I've been told there was an update around a month ago (When this problem started occurring) on Adobe's end. Does anyone have any duplicate scripts that I could try out? I haven't found anything suitable yet online. Or does anyone have any additions or suggestions I could use to solve this problem.
      Also I forgot to mention, this must be done through Javascript. Not through Adobe's built in Page number adding feature.
      Sub PaginatePDF()
      If AVDoc.Open(finalDLAPFolder & "DLAP_today.pdf", "") Then
        '//write JS-Code on a variable
        Ex = "  // Set Footer PageNo centered  " & vbLf _
        & "  var Box2Width = 50  " & vbLf _
        & "  for (var p = 0; p < this.numPages; p++)   " & vbLf _
        & "   {   " & vbLf _
        & "    var aRect = this.getPageBox(""Crop"",p);  " & vbLf _
        & "    var TotWidth = aRect[2] - aRect[0]  " & vbLf _
        & "     {  var bStart=((TotWidth/2)-(Box2Width/2)) " & vbLf _
        & "         var bEnd=((TotWidth/2)+(Box2Width/2)) + 5  " & vbLf _
        & "         var fp = this.addField(String(""xftPage""+p+1), ""text"", p, [bStart,45,bEnd,15]);   " & vbLf _
        & "         fp.value = ""Page: "" + String(p+1)+ ""/"" + this.numPages;  " & vbLf _
        & "         fp.textSize=9;  fp.readonly = true;  " & vbLf _
        & "         fp.alignment=""center"";  " & vbLf _
        & "     } " & vbLf _
      '//Execute JS-Code
      AForm.Fields.ExecuteThisJavaScript Ex
      End If
      Set finalPDF = AVDoc.GetPDDoc
      finalPDF.Save PDSaveCollectGarbage, finalDLAPFolder & "DLAP_today.pdf"
      'finalPDF.Save PDSaveFull, finalDLAPFolder & "DLAP_today.pdf"
      AVDoc.Close 1
      finalPDF.Close
      ' copy out to the sharepoint site
      fso.CopyFile finalDLAPFolder & "DLAP_today.pdf", PublishedDLAPFolder & "DLAP_today.pdf"
      Set AVDoc = Nothing
      Set app = Nothing
      Set finalPDF = Nothing
      Set AForm = Nothing
      End Sub
