2 Replies Latest reply: Aug 15, 2013 6:58 AM by Bill Hunt RSS
    transferring vhs video from vhs recorder to Photo Elements 11
    peteanddaph
      Can we transfer vhs video from a vhs recorder to Photo Elements 11
      I am running Windows 7 64 bit
      We were under the impression that this could be done
        • 1. Re: transferring vhs video from vhs recorder to Photo Elements 11
          nealeh Community Member
          You can transfer VHS directly to PRE via a Firewire digitizer such as the Canopus range of digitizers. This gives you the best quality and sound synchronisation.
          There are a wide range of cheap USB digitizers available but these cannot be used to transfer directly into PRE. You need to use their supplied software to capture the video and then transfer that clip to PRE like any other media. These USB digitizers and their software are of variable quality so if you go that route check independent online reviews and browse their support forums. Before I switched to the high end Canopus ADVC300 I had quite good results with the digitizer provided with Magix 'Rescue your Videotapes' product - but only after a lot of experimenting with different settings as there was a lot of audio out-of-sync issues with the default settings.
          Cheers,
          Neale
          Insanity is hereditary, you get it from your children.
          • 2. Re: transferring vhs video from vhs recorder to Photo Elements 11
            Bill Hunt CommunityMVP
            In addition to Neale's excellent suggestions, this article might give you a bit more background, but in the end, it's basically "what Neale said... "   http://forums.adobe.com/message/3748554#3748554
            Good luck, and happy editing,
