5 Replies Latest reply on Aug 15, 2013 6:35 AM by resdesign
    Using Jquery to show and hide symbols in Edge Animate
    davieduck89
      Hoping somebody can help me with this.
      I have a project in Edge with a couple of screens as symbols on layers in the main timeline. I've been trying to write a function in the global scope that I can call from all the buttons, to show and hide screens.
      So far I have a function that looks like this:
      function mainScreenOut (){
           sym.$("screen1").hide();
      But this and many variations don't seem to work.
      If anybody could help me understand how to use these jquery commands properly, it would be much appreciated.
        • 1. Re: Using Jquery to show and hide symbols in Edge Animate
          resdesign Adobe Community Professional & MVP
          Where are your buttons in relation to the screens?
          Are your screens on the main timeline? If so, you can also use display on/off. The default is always on.
          sym.$('screen').hide(); is correct syntax but it depends where and how you use it.
          • 2. Re: Using Jquery to show and hide symbols in Edge Animate
            davieduck89 Level 1
            The buttons are symbols, within a symbol. And the screens are on the main timeline. But I think I've solved this now. This is what I did:
            Because I couldn't figure out a way to show/hide the screen symbols themselves, I put them into their own div tags and targeted those instead, from the buttons.
            So, I ended up with each of my screens inside their own  encompassing div tags, and my code on the button symbol (nested in a symbol that is on the main timeline) ended up looking like this:
            if (mainPageActive == false){
            sym.getComposition().getStage().$("mainscreen1").fadeTo(1000,0.2);
            sym.getComposition().getStage().$("mainscreen1").css("pointer-events","none");
            sym.getComposition().getStage().$("mainscreen2").css("z-index", +1);
            sym.getComposition().getStage().getSymbol('screen2').play("on");
            toolTipActive = false;
            Where "mainscreen1" is the div tag sitting on the main timeline, that I had to wrap around the screen symbol.
            I suppose the only question that remains for me is:
            If what I've had to do here is true for everything, does this mean there's no way to use jquery commands to target SYMBOLS to do the same thing? Can I only target elements within a symbol, and not the symbol itself?
            • 3. Re: Using Jquery to show and hide symbols in Edge Animate
              Of course you can. It is just that you did not do it right because you did not address the target properly.
              If your buttons are inside a symbol and you are targetting another symbol then you need to do it this way:
              sym.getSymbol('symbolContainingtheButtons').$('yourbutton').click(function(){
                 // go back to the main timeline with sym.getComposition().getStage()
                   sym.getComposition().getStage().$('yourscreen').hide();
              Beware, this editor adds spaces in publishing.
              • 4. Re: Using Jquery to show and hide symbols in Edge Animate
                davieduck89 Level 1
                Ah! Thank you very much. You've been very helpful
