First a question:
Is anyone running RoboHelp (i.e., building a project) in Mac
OS Leopard? If so, do you need a Windows emulator? I'm guessing
success would be more likely on an Intel-based Mac than on a PPC
machine.
I opened some WebHelp output packages in Leopard on an Intel
MacBook. Mostly, it works pretty well. There are some differences
in formatting. It doesn't look exactly like the IE display. Text
sizes are different. Navigating doesn't work precisely the same as
in IE.
The big news is that the Search and Index don't default to
the old list style. They display, and the search form works, the
same as in IE. (Reminder: Text looks different.)
Firefox and Safari perform about equally well, but each has
its own quirks.
Some hiccups lin Safari loading a long Index from a large
merged project. Once it's completely loaded, the list of keywords
displays completely. Be patient.
In both browsers the Index type-to-find function works, and
the results correctly list multiple found topics or open a single
found topic. Search results work fine in both.
Firefox needs Esc to stop spinning its wheels. TOC books
won't open and TOC might be inoperable, until you click Esc.
Not sure about Reload from the browser toolbar. Safari
reloads the launch topic rather than the one you were viewing.
Firefox reloads the current topic, but not the associated Nav
Bar. (Note: Possibly this is caused by some patches I've made in
the output. If you're getting a normal reload, please post your
results.)
The breadcrumbs "Home" link gets confused when you have a
subproject up. In my case, Firefox loaded the home page for the
parent project, but kept the subproject's TOC. The browser reload
button didn't fix it.
Text display problems might be solved by tinkering with the
alternative .css stylesheet, if that's what they both use. A
different font might display better (I use both Arial and Verdana.
Verdana may default to Geneva: Sans serif, but shapes and sizes not
like Arial's.)
That's all I had time for; didn't test the Netscape browser.
Didn't test browsing with tabs against same-or-new-window. I'm not
planning to take this any further unless and until I need to
publish for a Mac environment.
If anyone has more experience testing or using Leopard for
WebHelp, please post.
Thanks.
Harvey
