3 Replies Latest reply on Aug 16, 2013 9:45 AM by Kari Puikkonen
    Apply paragraph to the next paragraph after the found  paragraph
    Kari Puikkonen
      A help would be appreciated!
      I can't understand who this script is not working.
      The idea is to find certain paragraph style and apply chosen (next) style to it.
      But nothing happens and i get this error: --> error number -1728
      Thanks in advance!
      tell application "Adobe InDesign CS6"
                set myDoc to active document
                set myParaList to name of every paragraph style of myDoc
                set myDialog to make dialog with properties {name:"Paragraph Styles"}
                tell myDialog
                          tell (make dialog column)
                                    tell (make border panel)
        make static text with properties ¬
        {static label:"Choose a paragraph style before next style", min width:150}
                                              end tell
                                                        set myPresetsDropdown to make dropdown with properties ¬
        {string list:myParaList, selected index:0, min width:150}
                                              end tell
                                    end tell
        {static label:"Choose a paragraph style of next style", min width:150}
                                              end tell
                                                        set myPresetsDropdown2 to make dropdown with properties ¬
                                              end tell
                                    end tell
                          end tell
                end tell
                set myResult to show myDialog
                if myResult = true then
        -- +1 gets the correct name because list starts at 0
                          set myPara to item ((selected index of myPresetsDropdown) + 1) of myParaList
                          set mychangePara to item ((selected index of myPresetsDropdown2) + 1) of myParaList
                end if
        destroy myDialog
                set theStories to object reference of stories of myDoc
                repeat with theStory in theStories
                          try
                                    set theParaStyles to name of applied paragraph style of object reference of paragraphs of theStory
                                    repeat with x from 1 to (count of theParaStyles) - 1
                                              if myPara = contents of item x of theParaStyles then
        -- change the number accordingly
        applyPara(x + 1, theStory, mychangePara) of me
                                              end if
                                    end repeat
                          end try
                end repeat
      end tell
      on applyPara(paraNum, storyRef, mychangePara)
                          repeat
                                    set changeStyle to mychangePara
                                    set applied paragraph style of paragraph paraNum of storyRef to changeStyle
                                    exit repeat
                          end repeat
                end tell
      end applyPara
