Any idea about the below error. I am getting this while submitting a form but this happens only in production.
'Element '' is undefined in a Java object of type class coldfusion.filter.FormScope'
Please help if any one have come across the same situation.
It's a bit difficult to say anything without the full error message and the code it relates to.
But what does the error say: you're trying to reference a form variable, that doesn't exist. I suspect this is because you're trying to reference a form variable, that doesn't exist. Just a guess.
The curious bit is that said form variable doesn't appear to have a name. I suspect you've got some code that acts on dynamically-named form fields, and the code has a logic error in it.
Adam
Adam
Thanks Adam.... I got the issue. I was following the way you showed me. Actually a value returning from LDAP is using inside a form structure but it was empty.
Really appreciating your help.
