1. Re: Miscellaneous Change(s) warning on Signatures panel when document signed twice
JP Hackworth Aug 19, 2013 1:56 PM (in response to Innokentiy Ivanov)Hello Innokentiy,
Creating the second signature field is being counted as a change. A quick way around this is to sign the document twice (as you did), then right-click on each signature field and select "Clear Signature". Save the document, then send it out for signing. As long as users click on those existing signature fields to sign it, you will avoid the "miscellaneous changes" message.
2. Re: Miscellaneous Change(s) warning on Signatures panel when document signed twice
Innokentiy Ivanov Aug 19, 2013 3:13 PM (in response to JP Hackworth)Hello JP,
Thank you for the clarification and a suggestion how to overcome the issue. Still there is a question as to why signing an empty field is not counted as a change, while adding a brand new signature (without altering the document in any other way) is.
I am worrying that our users will be frightened by the 'miscellaneous change' message (at least until they have a clear explanation that the 'change' is only related to the signature), so we will probably end up employing the empty fields-based solution... which also has certain lacks. In general case we don't know the number of signers beforehand, so we will have to create a dedicated page with 6-8 empty fields to cover for the maximal number of signers. Next, as far as I understand, the document can be signed by anyone if it contains unsigned fields, - in other words, say, the 3rd signer can't prevent the document with 8 unsigned fields from being signed for 5 more times in future (as he would normally do by 'locking the document after signing'), can he?
Thanks and best regards,
Innokentiy
3. Re: Miscellaneous Change(s) warning on Signatures panel when document signed twice
JP Hackworth Aug 19, 2013 5:18 PM (in response to Innokentiy Ivanov)I initially thought it would be preferable to allow brand new signatures without such a warning, but on reflection I can see ways it could be creatively abused to "edit" the document.
This is consistent with what I've seen as well; the "lock document" option only appears when signing the last remaining signature field. Having the option to lock it early sounds like a good candidate for a feature request.
4. Re: Miscellaneous Change(s) warning on Signatures panel when document signed twice
Innokentiy Ivanov Aug 20, 2013 11:03 AM (in response to JP Hackworth)JP,
Your concerns are reasonable, indeed the signing instrument can potentially be used for changing the way the document is rendered, and 'edit' it in this way, and there is actually nothing wrong if this fact is reported to the user. Yet the major thing I'm looking for here is clarity. Specifically, a '1 signature widget was added' seems a way better comment to me rather than an abstract '1 miscellaneous change' entry.
Innokentiy
5. Re: Miscellaneous Change(s) warning on Signatures panel when document signed twice
George_Johnson Aug 20, 2013 11:19 AM (in response to Innokentiy Ivanov)For what it's worth, it's possible to preconfigure digital signature fields so only certain people are allowed to sign them. This obviously won't work in cases where you need to allow anyone to sign, but if you have a known set of users it might be helpful.
6. Re: Miscellaneous Change(s) warning on Signatures panel when document signed twice
Kees de Wit Aug 24, 2013 3:24 AM (in response to Innokentiy Ivanov)This message is not very helpful for our customers as well. Most are confused about the miscellaneous comment (in case of multiple signatures). It needs a better description of the change instead of the current miscellaneous message.
