1 Reply Latest reply: Aug 19, 2013 11:09 AM by Apocalyptic0n3 RSS
    How to Encode Audio Recording from AS3 in PHP
    Apocalyptic0n3 Community Member
      I'm trying to build a way to encode AS3 audio recording data to WAV format in PHP. I was using a WAV encoder library in AS3 previously, but a 2 minute recording would take 4-6 minutes on mobile, depending on device. So I need to encode to WAV (or some other format that would make it usable) in PHP to take the load off the app.
      I've transated this encoder from Imbert Thibault to PHP. See the translation:
      function encode($samples, $channels = 2, $bits = 16, $rate = 44100){
          $data = create($samples);
          $length = strlen($data);
          $bytes = createHeaders($length, $channels, $bits, $rate);
          $bytes .= $data;
          return $bytes;
      function create($samples) {
          $newBytes = '';
          $bytes = unpack("f*", $samples);
          foreach ($bytes as $value) {
              $newBytes .= pack("V*",$value * 0x7FFF);
          return $newBytes;
      function createHeaders($length, $channels = 2, $bits = 16, $rate = 44100) {
          $RIFF = "RIFF";
          $WAVE = "WAVE";
          $FMT = "fmt ";
          $DATA = "data";
          $header  = '';
          $header .= $RIFF;
          $header .= pack("I*", $length + 44);
          $header .= $WAVE;
          $header .= $FMT;
          $header .= pack("I*", 16);
          $header .= pack("v*", 1);
          $header .= pack("v*", $channels);
          $header .= pack("I*", $rate);
          $header .= pack("I*", ( $rate * $channels * ($bits >> 3)));
          $header .= pack("v*", ($channels * ($bits >> 3)));
          $header .= pack("v*", $bits);
          $header .= $DATA;
          $header .= pack("I*", $length);
          return $header;
      That will create a readable file at the correct length (so the headers are obviously correct), but there is only silence when it is played. If I change the pack format in "create()" to "f*" (float, instead of unsigned 32-bit little endian int), I get static and I can faintly hear the sound in the background. I cannot adjust that multiplier to clear up the static, however. (EDIT: Before it is mentioned, I know the asterisk is not needed for most if not all of the pack formats. It was something I tried to see if it would fix things and I never deleted it)
      The file itself is created as so:
      private function start():void {
                if ( !mic ) {
                          this.mic = Microphone.getMicrophone();
                          this.mic.rate = 44;
                          this.mic.setSilenceLevel( 0, 10000 );
                          this.recording = new ByteArray();
              this.recording.length = 0; //reset byte array in case this is not first recording
                this.mic.addEventListener( SampleDataEvent.SAMPLE_DATA, this.saveSample );
      private function saveSample( e:SampleDataEvent ):void {
                while( e.data.bytesAvailable ) {
                          var byte:Number = e.data.readFloat();
                          this.recording.writeFloat( byte );
      public function stopRecording():void {
                var file:File = File.applicationStorageDirectory.resolvePath( "audio-recording.wav" );
                this.fs.open( file, FileMode.WRITE );
                this.fs.writeBytes( this.recording );
                this.fs.close();
      I am trying to encode the file saved in stopRecording(). At this point, I don't know what to do. I tried translating another encoder as well, but that seemed to run through memory like it was nothing.
      Does anyone have any suggestion as to what the problem is? Both encoders work just fine in AS3. Is it a problem with writing the file? Problem with writing the audio data to the byte array? Any suggestions at all at this point will be useful
        • 1. Re: How to Encode Audio Recording from AS3 in PHP
          So I was unable to figure out how to do it via PHP, but I did figure out how to do it in AS3 in a way that is both efficient and freaking fast. I realized that the slow bit of the encode was looping through the byte array, reading each individual byte, manipulating it, and writing it into another byte array. It is an inefficient process, but needed if you want to abstract the encoder from the recorder. The key was not to abstract it and instead do the encode on-the-fly as the recording is happening.
          So you record like this:
                    e.data.position = 0;
                              this.recording.writeShort( e.data.readFloat() * (0x7fff) );
          That will do the encode that Imbert Thibault wrote as you are doing a necessary task (pulling the data from the stream and saving it to a byte array).
          With that, the data is written as it needs to be and we just need to add the headers to make it an actual WAV file.
          this.recording.position = 0;
          this.recording = this.writeHeaders( this.recording, 1 );
          private function writeHeaders( data:ByteArray, channels:int=2, bits:int=16, rate:int=44100 ):ByteArray {
                    data.position = 0;
                    var bytes:ByteArray = new ByteArray();
                    bytes.length = 0;
                    bytes.endian = Endian.LITTLE_ENDIAN;
                    bytes.writeUTFBytes( "RIFF" );
                    bytes.writeInt( uint( data.length + 44 ) );
                    bytes.writeUTFBytes( "WAVE" );
                    bytes.writeUTFBytes( "fmt " );
                    bytes.writeInt( uint( 16 ) );
                    bytes.writeShort( uint( 1 ) );
                    bytes.writeShort( channels );
                    bytes.writeInt( rate );
                    bytes.writeInt( uint( rate * channels * ( bits >> 3 ) ) );
                    bytes.writeShort( uint( channels * ( bits >> 3 ) ) );
                    bytes.writeShort( bits );
                    bytes.writeUTFBytes( "data" );
                    bytes.writeInt( data.length );
                    bytes.writeBytes( data );
                    bytes.position = 0;
                    return bytes;
          And oila. That is a valid WAV file created with no delay after ending the recording (whereas previously, I was experienced a delay 3x the length of the recording on my Nexus 4). I know this is not a very popular issue (Google, Adobe, these forums, and StackOverflow were pretty much useless in trying to solve this), but hopefully this solution will help someone along the line.
          EDIT: As an afterthought, make sure the ByteArray you record into has its endian property set to Endian.LITTLE_ENDIAN immediately after instantiation. WAV files require that format and are unreadable if not set to that.
