1 Reply Latest reply on Aug 17, 2013 8:53 PM by joneisele
    CS6, DNxHD, and 1080p/60?
    joneisele
      I have some 1920x1080, 60fps progressive footage that I want to export into a master file using the DNxHD codec.   I have used DNxHD prior with 1080i and 720p footage.   I selected Quicktime as the format, then Avid DNxHD as the codec, then when I go to the codec settings I don't see an option for 1080/60p.   The dnxhd.pdf file from Avid shows a bunch of HD formats supported including 1080/60p.   Suggestions?    Thanks.
      Avid DNxHD is available in multiple HD encoding choices per resolution/frame rate combination, each
      identified by bandwidth (megabits/second) and bit depth, as shown below.
      Project Format Resolution Frame Size Color Space Bits FPS Mbps Min/GB
      1080p/60 Avid DNxHD 440x 1920 x 1080 4:2:2 10 60 440 0.325
      1080p/60 Avid DNxHD 440 1920 x 1080 4:2:2 8 60 440 0.325
      1080p/60 Avid DNxHD 290 1920 x 1080 4:2:2 8 60 291 0.492
      1080p/60 Avid DNxHD 90 1920 x 1080 4:2:2 8 60 90 1.585
