5 Replies Latest reply on Aug 18, 2013 5:57 PM by Gargoyle Software, LLC
    MOV file imported to Mocha AE is white
    Gargoyle Software, LLC Level 1
      I have a .mov file I shot with my iPhone 4S to start playing with Mocha tracking.  I imported the clip to After Effects and created a new composition out of it.  It plays just fine in AE.  Then I went to Animation -> Track in Mocha and then mocha window came up.  I'm just getting a solid white video for all of the frames.    I ran mediainfo on the file and got the below output, which I'm hoping is helpful in telling me what I'm doing wrong.  When the mocha window came up I told it the frame rate was 29.97, and I left everything else at the default.
      General
      Complete name                            : IMG_0167.MOV
      Format                                   : MPEG-4
      Format profile                           : QuickTime
      Codec ID                                 : qt
      File size                                : 53.7 MiB
      Duration                                 : 21s 48ms
      Overall bit rate                         : 21.4 Mbps
      Recorded date                            : 2013-08-17T16:45:30-0700
      Encoded date                             : UTC 2013-08-17 23:45:30
      Tagged date                              : UTC 2013-08-17 23:49:00
      Writing application                      : 6.1.3
      Writing library                          : Apple QuickTime
      Model                                    : iPhone 4S
      Make                                     : Apple
      Video
      Format                                   : AVC
      Format/Info                              : Advanced Video Codec
      Format profile                           : Baseline@L4.1
      Format settings, CABAC                   : No
      Format settings, ReFrames                : 1 frame
      Format settings, GOP                     : M=1, N=30
      Codec ID                                 : avc1
      Codec ID/Info                            : Advanced Video Coding
      Duration                                 : 21s 48ms
      Source duration                          : 21s 55ms
      Bit rate                                 : 21.3 Mbps
      Width                                    : 1 920 pixels
      Height                                   : 1 080 pixels
      Display aspect ratio                     : 16:9
      Rotation                                 : 180°
      Frame rate mode                          : Variable
      Frame rate                               : 29.970 fps
      Minimum frame rate                       : 28.571 fps
      Maximum frame rate                       : 30.000 fps
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Progressive
      Bits/(Pixel*Frame)                       : 0.343
      Stream size                              : 53.6 MiB (100%)
      Source stream size                       : 53.6 MiB (100%)
      Title                                    : Core Media Video
      Tagged date                              : UTC 2013-08-17 23:45:42
      Color primaries                          : BT.709
      Transfer characteristics                 : BT.709
      Matrix coefficients                      : BT.709
