1. Re: Fonts not syncing between machines...
graphicgoose Aug 19, 2013 2:17 PM (in response to graphicgoose)In addition....I restarted my laptop. All the 'new' fonts that I had synced at home were no longer available (in addition to the ones previously added on desktop), even though they were all still set to sync on Typekit. Again, I could add new fonts that I had never synced before, but fonts I had already synced were no longer available. Basically, it keeps whittling down the available fonts!
2. Re: Fonts not syncing between machines...
derekajack Aug 20, 2013 3:02 AM (in response to graphicgoose)Hi,
it would be useful to see your log files. You can get them from either location below, depending on your OS:
Mac:/Library/Application Support/Adobe/CoreSync/CoreSync-yyyy-mm-dd.log
(On Mac, you need to use the Go To Folder option from the Go option in Finder (menu at the top). Then in the pop up enter:
/users/username/Library/Application Support/Adobe/CoreSync/
Then select go, this will take you to the folder containing the .log files.)
Windows:
%APPDATA%/Adobe/CoreSync/CoreSync-yyyy-mm-dd.log
Then email them to me on djack@adobe.com
