1 Reply Latest reply on Aug 18, 2013 9:41 PM by Sajeev Sridharan
    function to check if a link is used many times
    bastieneichenberger Level 1
      I try to create a script to resize all links in a document. For this script I need a function to know if the same image is used many times.
      Has someone an ideas how to do this? I didn't find a function for that.
      My ideas would look like this:
      function is_link_used_many_time(link_item){
          // get all links
          var array_all_links = doc_package.links;
          // delete the link_item from the array
          // code
          //check if the array contains a link with the same name
          for(var i = 0; i<array_all_links.length; i++){
              var current_link = array_all_links[i];
              if(link_item.name == current_link.name){
                  alert("links used many time"+current_link.name);
                  // create a collection with all links
      Thanks you!
        • 1. Re: function to check if a link is used many times
          Sajeev Sridharan Level 4
          Try this,
          var doc = app.activeDocument;
          var links = doc.links;
          var count=0;
          for (var i = 0; i < links.length; i++)
              var image = links[i].name;
              for(c=0;c<links.length;c++)
                  if(links[i].name == links[c].name)
                      count++;
                      if(count>1)
                          var imagePage = doc.links[i].parent.parentPage.name;
                          alert("Image name: "+ links[i].name + "\rPage Number: " + imagePage + "\r" + count + " times used");
              count=0;
          Vandy
