4 Replies Latest reply on Aug 20, 2013 7:30 AM by ghoshy2010
    flashplayer problems
    ghoshy2010
      here are the steps I have gone through to fix this problem, when playing a prevideo(pre-recorded)the sound play back is intermitent, I get 2 second of sound then like it is being scanned or has lag where it do's not buffer fast enough, I have turned my Kaspersky 2013 off/turned hardware accelration off/ I have the latest drivers of graphic's/sound/windows xp,  and still version flashplayer ( You have version 11,8,800,97 installed, )still do's not play normal, dxdiag reads as follows;  and any help on why this happens would be nice as this never happened before installing flashplayer 11.0  also to add to this I am on fibre optic with speeds up to and including 71mb a second so pseed is not the answer ( i hope)
      System Information
      Time of this report: 8/18/2013, 23:32:59
             Machine name: HOME1-CY36RHS5Z
         Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.130503-0418)
                 Language: English (Regional Setting: English)
      System Manufacturer: 939M2
             System Model: 939Dual-SATA2
                     BIOS: Default System BIOS
                Processor: AMD Athlon(tm) 64 Processor 3500+,  MMX,  3DNow, ~2.2GHz
                   Memory: 2544MB RAM
                Page File: 1398MB used, 3027MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 9.0c (4.09.0000.0904)
      DX Setup Parameters: Not found
           DxDiag Version: 5.03.2600.5512 32bit Unicode
      DxDiag Notes
        DirectX Files Tab: No problems found.
            Display Tab 1: No problems found.
              Sound Tab 1: No problems found.
                Music Tab: No problems found.
                Input Tab: No problems found.
              Network Tab: No problems found.
      DirectX Debug Levels
      Direct3D:    0/4 (n/a)
      DirectDraw:  0/4 (retail)
      DirectInput: 0/5 (n/a)
      DirectMusic: 0/5 (n/a)
      DirectPlay:  0/9 (retail)
      DirectSound: 0/5 (retail)
      DirectShow:  0/6 (retail)
      Display Devices
              Card name: ATI Radeon HD 5400 Series
           Manufacturer: Advanced Micro Devices, Inc.
              Chip type: AMD Radeon Graphics Processor (0x68E1)
               DAC type: Internal DAC(400MHz)
             Device Key: Enum\PCI\VEN_1002&DEV_68E1&SUBSYS_30001787&REV_00
         Display Memory: 1024.0 MB
           Current Mode: 1024 x 768 (32 bit) (60Hz)
                Monitor: Default Monitor
        Monitor Max Res:
            Driver Name: ati2dvag.dll
         Driver Version: 6.14.0010.7270 (English)
            DDI Version: 9 (or higher)
      Driver Attributes: Final Retail
      Driver Date/Size: 6/11/2012 18:12:38, 305664 bytes
            WHQL Logo'd: Yes
        WHQL Date Stamp: n/a
                    VDD: n/a
               Mini VDD: ati2mtag.sys
          Mini VDD Date: 6/11/2012 19:57:18, 6629888 bytes
      Device Identifier: {D7B71EE2-2BA1-11CF-5168-0A10A1C2CB35}
              Vendor ID: 0x1002
              Device ID: 0x68E1
              SubSys ID: 0x30001787
            Revision ID: 0x0000
            Revision ID: 0x0000
            Video Accel: ModeMPEG2_C ModeMPEG2_D
      Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
               Registry: OK
           DDraw Status: Enabled
             D3D Status: Enabled
             AGP Status: Enabled
      DDraw Test Result: Not run
      D3D7 Test Result: Not run
      D3D8 Test Result: Not run
      D3D9 Test Result: Not run
      Sound Devices
                  Description: Realtek AC97 Audio
      Default Sound Playback: Yes
      Default Voice Playback: Yes
                  Hardware ID: PCI\VEN_10B9&DEV_5455&SUBSYS_08501849&REV_20
              Manufacturer ID: 65535
                   Product ID: 65535
                         Type: WDM
                  Driver Name: ALCXWDM.SYS
               Driver Version: 5.10.0000.5650 (English)
                  WHQL Logo'd: Yes
                Date and Size: 8/2/2004 21:09:18, 635281 bytes
                  Other Files:
              Driver Provider: Realtek Semiconductor Corp.
               HW Accel Level: Full
                    Cap Flags: 0xF5F
          Min/Max Sample Rate: 100, 192000
      Static/Strm HW Mix Bufs: 33, 32
      Static/Strm HW 3D Bufs: 33, 32
                    HW Memory: 0
             Voice Management: Yes
      EAX(tm) 2.0 Listen/Src: Yes, Yes
         I3DL2(tm) Listen/Src: Yes, Yes
      Sensaura(tm) ZoomFX(tm): No
                     Registry: OK
            Sound Test Result: Not run
      Sound Capture Devices
        Default Sound Capture: Yes
        Default Voice Capture: Yes
                    Cap Flags: 0x41
                 Format Flags: 0xFFF
      DirectMusic
              DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
           DLS Version: 1.00.0016.0002
          Acceleration: n/a
                 Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                        Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
                        Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                        Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
              Registry: OK
      DirectInput Devices
            Device Name: Mouse
               Attached: 1
          Controller ID: n/a
      Vendor/Product ID: n/a
              FF Driver: n/a
            Device Name: Keyboard
               Attached: 1
          Controller ID: n/a
              FF Driver: n/a
      Poll w/ Interrupt: No
               Registry: OK
      USB Devices
      + USB Root Hub
      | Vendor/Product ID: 0x10B9, 0x5237
      | Matching Device ID: usb\root_hub
      | Service: usbhub
      | Driver: usbhub.sys, 4/14/2008 01:15:38, 59520 bytes
      | Driver: usbd.sys, 8/23/2001 13:00:00, 4736 bytes
      +-+ USB Human Interface Device
      | | Vendor/Product ID: 0x046D, 0xC05A
      | | Matching Device ID: usb\class_03&subclass_01
      | | Service: HidUsb
      | | Driver: hidusb.sys, 4/14/2008 01:15:28, 10368 bytes
      | | Driver: hidclass.sys, 4/14/2008 01:15:28, 36864 bytes
      | | Driver: hidparse.sys, 4/14/2008 01:15:24, 24960 bytes
      | | Driver: hid.dll, 4/14/2008 06:41:56, 20992 bytes
      | +-+ HID-compliant mouse
      | | | Matching Device ID: hid_device_system_mouse
      | | | Service: mouhid
      | | | Driver: mouclass.sys, 4/14/2008 01:09:48, 23040 bytes
      | | | Driver: mouhid.sys, 8/23/2001 13:00:00, 12160 bytes
      Gameport Devices
      PS/2 Devices
      + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
      | Matching Device ID: *pnp0303
      | Service: i8042prt
      | Driver: i8042prt.sys, 4/14/2008 01:48:02, 52480 bytes
      | Driver: kbdclass.sys, 4/14/2008 01:09:48, 24576 bytes
      + Terminal Server Keyboard Driver
      | Matching Device ID: root\rdp_kbd
      | Upper Filters: kbdclass
      | Service: TermDD
      | Driver: termdd.sys, 4/14/2008 06:43:22, 40840 bytes
      + Terminal Server Mouse Driver
      | Matching Device ID: root\rdp_mou
      | Upper Filters: mouclass
      | Service: TermDD
      DirectPlay Service Providers
      DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
      DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
      DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
      DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
      Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
      IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
      Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
      Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
      DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
      DirectPlay Test Result: Not run
      Registry: OK
      DirectPlay Adapters
      DirectPlay8 Serial Service Provider: COM1
      DirectPlay8 IPX Service Provider: IPX Adapter 1 - (00000000,00138F9D8567)
      DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
      DirectPlay Voice Codecs
      Voxware VR12 1.4kbit/s
      Voxware SC06 6.4kbit/s
      Voxware SC03 3.2kbit/s
      MS-PCM 64 kbit/s
      MS-ADPCM 32.8 kbit/s
      Microsoft GSM 6.10 13 kbit/s
      TrueSpeech(TM) 8.6 kbit/s
      DirectPlay Lobbyable Apps
      Disk & DVD/CD-ROM Drives
            Drive: C:
      Free Space: 103.3 GB
      Total Space: 131.1 GB
      File System: NTFS
            Model: WDC WD1600AAJB-00PVA0
            Drive: F:
      Free Space: 1.9 GB
      Total Space: 2.0 GB
      File System: FAT
            Model:  ST96812AS SCSI Disk Device
            Drive: H:
      Free Space: 221.7 GB
      Total Space: 238.5 GB
      File System: NTFS
            Model:  WDC WD5000AAKS-2 SCSI Disk Device
            Drive: I:
      Free Space: 1.4 GB
      Total Space: 21.6 GB
      File System: NTFS
            Drive: J:
      Free Space: 178.1 GB
      Total Space: 228.5 GB
      File System: NTFS
            Drive: D:
            Model: TSSTcorp CD/DVDW TS-H552U
           Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/14/2008 01:10:48, 62976 bytes
            Drive: E:
            Model: SAMSUNG DVD-ROM SD-612
            Drive: G:
            Model: POLQT 12FKDIF SCSI CdRom Device
      System Devices
           Name: ALi 7101 Power Management Controller
      Device ID: PCI\VEN_10B9&DEV_7101&SUBSYS_71011849&REV_00\3&267A616A&0&39
         Driver: n/a
           Name: Realtek AC'97 Audio
      Device ID: PCI\VEN_10B9&DEV_5455&SUBSYS_08501849&REV_20\3&267A616A&0&40
         Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (English), 4/14/2008 05:41:58, 4096 bytes
         Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (English), 4/14/2008 05:42:44, 129536 bytes
         Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (English), 4/14/2008 00:46:38, 141056 bytes
         Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:16, 60160 bytes
         Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/14/2008 00:49:42, 146048 bytes
         Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (English), 4/14/2008 00:15:16, 49408 bytes
         Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 06:42:46, 23552 bytes
         Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.5650 (English), 8/2/2004 21:09:18, 635281 bytes
         Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0029 (English), 7/27/2004 17:01:36, 68096 bytes
         Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0031 (English), 7/27/2004 17:08:44, 15704576 bytes
         Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/5/2002 13:54:58, 141016 bytes
         Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0032 (English), 7/23/2004 16:32:32, 7546880 bytes
         Driver: C:\WINDOWS\system32\drivers\ALCXSENS.SYS, 5.10.0000.3513 (English), 2/24/2004 11:08:52, 400384 bytes
         Driver: C:\WINDOWS\system\crlds3d.dll, 4.12.0001.2002 (English), 11/21/2002 15:07:10, 765952 bytes
         Driver: C:\WINDOWS\system32\a3d.dll, 4.12.0001.2009 (English), 8/19/2003 19:36:16, 65536 bytes
         Driver: C:\WINDOWS\system32\Audio3D.dll, 4.12.0001.2009 (English), 8/19/2003 19:36:16, 65536 bytes
         Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0000.0002 (English), 2/9/2004 15:18:18, 155648 bytes
           Name: ULi SATA/RAID Controller (M1689/M1567)
      Device ID: PCI\VEN_10B9&DEV_5289&SUBSYS_52891849&REV_10\3&267A616A&0&91
         Driver: C:\WINDOWS\system32\DRIVERS\m5289.sys, 5.00.0003.0000 (English), 7/4/2005 14:21:00, 52480 bytes
           Name: ULi PCI Fast Ethernet Controller
      Device ID: PCI\VEN_10B9&DEV_5263&SUBSYS_52631849&REV_40\3&267A616A&0&88
         Driver: C:\WINDOWS\system32\DRIVERS\ULILAN51.SYS, 5.01.2600.0350 (English), 3/22/2005 21:36:40, 28672 bytes
           Name: PCI standard PCI-to-PCI bridge
      Device ID: PCI\VEN_10B9&DEV_524C&SUBSYS_00000000&REV_00\3&267A616A&0&10
         Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 01:06:46, 68224 bytes
      Device ID: PCI\VEN_10B9&DEV_524B&SUBSYS_00000000&REV_00\3&267A616A&0&08
      Device ID: PCI\VEN_10B9&DEV_5249&SUBSYS_00000000&REV_00\3&267A616A&0&30
           Name: ULi AGP v3.0 Controller
      Device ID: PCI\VEN_10B9&DEV_5246&SUBSYS_00000000&REV_00\3&267A616A&0&28
         Driver: C:\WINDOWS\system32\DRIVERS\AGPKX.SYS, 5.01.2600.2300 (English), 5/3/2005 18:31:56, 45056 bytes
           Name: Standard Enhanced PCI to USB Host Controller
      Device ID: PCI\VEN_10B9&DEV_5239&SUBSYS_52391849&REV_01\3&267A616A&0&9B
         Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:36, 30208 bytes
         Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:38, 143872 bytes
         Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 06:42:10, 74240 bytes
         Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:38, 59520 bytes
         Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 06:41:56, 7168 bytes
           Name: ALi PCI to USB Open Host Controller
      Device ID: PCI\VEN_10B9&DEV_5237&SUBSYS_52371849&REV_03\3&267A616A&0&9A
         Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:36, 17152 bytes
      Device ID: PCI\VEN_10B9&DEV_5237&SUBSYS_52371849&REV_03\3&267A616A&0&99
      Device ID: PCI\VEN_10B9&DEV_5237&SUBSYS_52371849&REV_03\3&267A616A&0&98
           Name: ALi M5229 PCI Bus Master IDE Controller
      Device ID: PCI\VEN_10B9&DEV_5229&SUBSYS_52291849&REV_C7\3&267A616A&0&90
         Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/14/2008 01:10:30, 24960 bytes
         Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 01:10:32, 96512 bytes
         Driver: C:\WINDOWS\system32\DRIVERS\aliide.sys, 1.02.0000.0000 (English), 8/23/2001 13:00:00, 5248 bytes
           Name: PCI standard host CPU bridge
      Device ID: PCI\VEN_10B9&DEV_1695&SUBSYS_00000000&REV_00\3&267A616A&0&00
         Driver: n/a
      Device ID: PCI\VEN_10B9&DEV_1689&SUBSYS_00000000&REV_00\3&267A616A&0&20
         Driver: n/a
           Name: PCI standard ISA bridge
      Device ID: PCI\VEN_10B9&DEV_1563&SUBSYS_00000000&REV_70\3&267A616A&0&38
         Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 01:06:42, 37248 bytes
           Name: AFL9RNJR IDE Controller
      Device ID: PCI\VEN_105A&DEV_3D18&SUBSYS_A8D5226F&REV_01\4&5D18F2DF&0
         Driver: n/a
      Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&267A616A&0&C3
         Driver: n/a
      Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&267A616A&0&C2
         Driver: n/a
      Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&267A616A&0&C1
         Driver: n/a
      Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&267A616A&0&C0
         Driver: n/a
           Name: Microsoft UAA Bus Driver for High Definition Audio
      Device ID: PCI\VEN_1002&DEV_AA68&SUBSYS_AA681787&REV_00\4&70BCEE6&0&0108
         Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/13/2008 23:06:06, 144384 bytes
           Name: ATI Radeon HD 5400 Series
      Device ID: PCI\VEN_1002&DEV_68E1&SUBSYS_30001787&REV_00\4&70BCEE6&0&0008
         Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.7270 (English), 6/11/2012 19:57:18, 6629888 bytes
         Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0024 (English), 6/11/2012 17:33:46, 53248 bytes
         Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.7270 (English), 6/11/2012 18:12:38, 305664 bytes
         Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0557 (English), 6/11/2012 17:28:54, 675840 bytes
         Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 6/11/2012 17:51:30, 26112 bytes
         Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0920 (English), 6/11/2012 18:10:24, 4579904 bytes
         Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0010.0363 (English), 6/11/2012 17:50:30, 3565440 bytes
         Driver: C:\WINDOWS\system32\atiicdxx.dat, 4/12/2012 20:30:10, 637743 bytes
         Driver: C:\WINDOWS\system32\amdpcom32.dll, 6.14.0010.0023 (English), 6/11/2012 17:25:50, 65024 bytes
         Driver: C:\WINDOWS\system32\atimpc32.dll, 6.14.0010.0023 (English), 6/11/2012 17:25:50, 65024 bytes
         Driver: C:\WINDOWS\system32\atiadlxx.dll, 6.14.0010.1106 (English), 6/11/2012 17:35:42, 241664 bytes
         Driver: C:\WINDOWS\system32\ativvaxx.cap, 6/11/2012 17:45:24, 2971136 bytes
         Driver: C:\WINDOWS\system32\atiapfxx.exe, 6.14.0010.1001 (English), 6/11/2012 17:45:28, 163840 bytes
         Driver: C:\WINDOWS\system32\atiapfxx.blb, 6/11/2012 17:46:14, 263840 bytes
         Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 6/11/2012 17:48:28, 53248 bytes
         Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 6/11/2012 17:35:20, 17408 bytes
         Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 17:01:04, 24064 bytes
         Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4265 (English), 6/11/2012 17:49:48, 643072 bytes
         Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4179 (English), 6/11/2012 17:51:04, 192512 bytes
         Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2563 (English), 6/11/2012 17:51:52, 212992 bytes
         Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.15.0006.0006 (English), 6/11/2012 17:51:40, 163840 bytes
         Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2514 (English), 6/11/2012 17:51:20, 43520 bytes
         Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0173 (English), 6/11/2012 17:40:58, 835584 bytes
         Driver: C:\WINDOWS\system32\ATIDEMGX.dll, 2.00.4545.22014 (English), 6/11/2012 18:13:50, 442368 bytes
         Driver: C:\WINDOWS\system32\atibtmon.exe, 2.00.0000.0000 (English), 5/11/2009 22:35:28, 118784 bytes
         Driver: C:\WINDOWS\system32\atiok3x2.dll, 6.14.0010.11733 (English), 6/11/2012 17:36:28, 638976 bytes
         Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.11733 (English), 6/11/2012 18:38:56, 19587072 bytes
         Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4006 (English), 6/11/2012 18:15:08, 307200 bytes
         Driver: C:\WINDOWS\atiogl.xml, 3/13/2012 00:10:30, 38177 bytes
         Driver: C:\WINDOWS\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 6/22/2009 16:34:18, 45056 bytes
         Driver: C:\WINDOWS\system32\ATIODE.exe, 1.00.0000.0001 (English), 8/27/2010 19:32:08, 294912 bytes
      DirectX Components
         ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 279552 bytes
      ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 27136 bytes
         dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 10496 bytes
          d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 1179648 bytes
      d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 8192 bytes
          d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 1689088 bytes
         d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 436224 bytes
      d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 824320 bytes
      d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 590336 bytes
         d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 350208 bytes
        d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 47616 bytes
      d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 34816 bytes
         dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 33040 bytes
        dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 229888 bytes
      dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 23552 bytes
      dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 42768 bytes
      dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 57344 bytes
      dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:18 29696 bytes
        dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:18 17920 bytes
         dpnet.dll: 5.03.2600.6311 English Final Retail 11/2/2012 03:02:42 375296 bytes
      dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:39:22 3072 bytes
      dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:39:20 3072 bytes
      dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 212480 bytes
      dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:20 83456 bytes
        dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 116736 bytes
        dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 21504 bytes
      dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 35328 bytes
      dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 60928 bytes
      dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 53520 bytes
        dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 158720 bytes
      dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 181760 bytes
         dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 44032 bytes
      diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 394240 bytes
           joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:42 68608 bytes
         gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 76800 bytes
           pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:04 35328 bytes
      gameenum.sys: 5.01.2600.5512 English Final Retail 4/14/2008 01:15:30 10624 bytes
        dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 367616 bytes
      dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 1293824 bytes
        dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 19456 bytes
         dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 181248 bytes
      dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 71680 bytes
        dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 104448 bytes
        dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 28672 bytes
      dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 61440 bytes
         dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 181248 bytes
      dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 35840 bytes
      dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 105984 bytes
      dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 103424 bytes
      dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 82432 bytes
        system.dll: 1.01.4322.2503 English Final Retail 8/12/2013 15:34:53 1232896 bytes
      Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 2/27/2013 20:37:07 473600 bytes
      Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 2/27/2013 20:37:00 2676224 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 2/27/2013 20:37:01 2846720 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 2/27/2013 20:37:01 563712 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 2/27/2013 20:37:01 567296 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 2/27/2013 20:37:01 576000 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 2/27/2013 20:37:02 577024 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 2/27/2013 20:37:02 577536 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 2/27/2013 20:37:02 577536 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 2/27/2013 20:37:02 578560 bytes
      Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 2/27/2013 20:37:07 578560 bytes
      Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 2/27/2013 20:37:07 145920 bytes
      Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 2/27/2013 20:37:07 159232 bytes
      Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 2/27/2013 20:37:07 364544 bytes
      Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 2/27/2013 20:37:07 178176 bytes
      Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 2/27/2013 20:37:06 53248 bytes
      Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 2/27/2013 20:37:07 12800 bytes
      Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 2/27/2013 20:37:06 223232 bytes
         dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 619008 bytes
         dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 1227264 bytes
      dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 2113536 bytes
         mfc40.dll: 4.01.0000.6151 English Beta Retail 9/18/2010 07:53:25 954368 bytes
         mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 14:33:55 978944 bytes
      wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 06:42:12 22528 bytes
      amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:41:50 70656 bytes
      devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:41:52 59904 bytes
        dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 06:41:54 498742 bytes
      mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:41:58 35328 bytes
      mpg2splt.ax: 6.05.2600.6333 English Final Retail 1/2/2013 07:49:10 148992 bytes
         msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:00 14336 bytes
        encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 20480 bytes
          qasf.dll: 11.00.5721.5262 English Final Retail 1/30/2009 21:34:02 211456 bytes
          qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:04 192512 bytes
           qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:04 279040 bytes
          qdvd.dll: 6.05.2600.6169 English Final Retail 11/3/2011 16:28:36 386048 bytes
         qedit.dll: 6.05.2600.6404 English Final Retail 6/4/2013 08:23:02 562688 bytes
      qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 23:51:34 733696 bytes
        quartz.dll: 6.05.2600.6333 English Final Retail 1/2/2013 07:49:10 1292288 bytes
      strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 09:00:21 247326 bytes
      iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 06:42:44 199680 bytes
        ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 06:42:44 848384 bytes
      ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 06:41:56 120320 bytes
      ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 06:41:56 338432 bytes
      ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 06:41:56 755200 bytes
      ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 06:41:56 200192 bytes
      ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 06:41:56 183808 bytes
         ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 06:42:44 154624 bytes
      mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 10:01:48 204800 bytes
            ks.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:46:38 141056 bytes
        ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 129536 bytes
        ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:58 4096 bytes
        stream.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:15:16 49408 bytes
      mspclock.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:52 5376 bytes
         mspqm.sys: 5.01.2600.5512 English Final Retail 4/14/2008 01:09:52 4992 bytes
      mskssrv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:54 7552 bytes
        swenum.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:54 4352 bytes
         mstee.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:52 5504 bytes
         ipsink.ax: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:44 16384 bytes
      mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:44 118272 bytes
        ndisip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 10880 bytes
      streamip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:22 15232 bytes
      msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:02 1428992 bytes
          slip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 11136 bytes
      nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:26 85248 bytes
      ccdecode.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 17024 bytes
        vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:44 30208 bytes
         msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 18:11:44 17920 bytes
      kstvtune.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 61952 bytes
         ksxbar.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 43008 bytes
      kswdmcap.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 91136 bytes
      vfwwdm32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 05:42:10 53760 bytes
      wstcodec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:26 19200 bytes
      wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:12 50688 bytes
      DirectShow Filters
      WDM Streaming VBI Codecs:
      NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.5512
      CC Decoder,0x00200000,2,1,,5.03.2600.5512
      WST Codec,0x00200000,1,1,,5.03.2600.5512
      DirectShow Filters:
      WMAudio Decoder DMO,0x00800800,1,1,,
      WMAPro over S/PDIF DMO,0x00600800,1,1,,
      WMA Voice Decoder DMO,0x00600800,1,1,,
      WMVideo 8 Decoder DMO,0x00800001,1,1,,
      Mpeg4s Decoder DMO,0x00800001,1,1,,
      WMV Screen decoder DMO,0x00800001,1,1,,
      WMVideo Decoder DMO,0x00800001,1,1,,
      Mpeg43 Decoder DMO,0x00800001,1,1,,
      Mpeg4 Decoder DMO,0x00800001,1,1,,
      WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
      VP6 Decompressor,0x00800000,1,1,vp6dec.ax,6.04.0002.0000
      ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.01.3530.0000
      Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6333
      ffdshow DXVA Video Decoder,0xff800002,2,1,ffdshow.ax,1.01.3530.0000
      ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.01.3530.0000
      Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0030
      ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.01.3530.0000
      ATI Ticker,0x00200000,0,1,Ticker.ax,
      DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
      MPC - Mpeg Source (Gabest),0x00400000,0,0,MpegSplitter.ax,1.03.2116.0000
      MainConcept MPEG Demultiplexer,0x00800100,1,2,mc_demux_mp2_ds.ax,9.06.0008.8663
      Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0030
      DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0002.0001
      Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6333
      WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5262
      Audio Source,0x00200000,0,1,wmprevu.dll,7.01.0000.3055
      Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5262
      AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6333
      WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6333
      Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
      Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
      RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
      AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
      DivX AAC Decoder,0x00800000,1,1,daac.ax,8.08.0000.41966
      WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      StreamBufferSink,0x00200000,0,0,sbe.dll,
      WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Nero Resize,0x00200000,1,1,NeResize.ax,3.02.0000.0030
      MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
      Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
      WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
      Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
      WDM Capture Device,0x00200000,1,0,wmesrcwp.dll,7.01.0000.3055
      MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6333
      SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
      ATI MPEG File Writer,0x00200000,1,0,atimpenc.dll,11.06.0000.10707
      ATI MPEG Video Decoder,0x00400000,1,2,atimpenc.dll,11.06.0000.10707
      MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
      Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0030
      MPV Decoder Filter,0x40000002,1,1,Mpeg2DecFilter.ax,1.00.0000.0003
      MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.6333
      MPC - MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.03.2116.0000
      ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
      Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,3.02.0000.0030
      Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0030
      Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0030
      Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,3.02.0000.0030
      Nero Digital AVC Video Enc,0x00200000,1,2,,
      Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0030
      MPC - FLV Splitter (Gabest),0x00600000,1,1,FLVSplitter.ax,1.03.2116.0000
      Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
      MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6333
      MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
      File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5262
      Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,3.02.0000.0030
      Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,3.02.0000.0030
      WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
      DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
      Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
      Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
      Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
      Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,3.02.0000.0030
      Haali Media Splitter,0x00800001,0,1,splitter.ax,1.10.0175.0000
      Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.10.0175.0000
      WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,3.02.0000.0030
      Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Nero ES Video Reader,0x00600000,0,1,NDParser.ax,3.02.0000.0030
      DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0002.0001
      MPC - MP4 Splitter,0x00600000,1,1,MP4Splitter.ax,1.03.2116.0000
      Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,3.02.0000.0030
      Color Converter,0x00200000,1,1,declrds.ax,7.01.0000.3055
      Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
      ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
      ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5262
      NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
      ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc.dll,11.06.0000.10707
      ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6333
      CoreAAC Audio Decoder,0x00800000,1,1,CoreAAC.ax,1.02.0000.0573
      Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5262
      Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
      Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,3.02.0000.0030
      MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
      Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169
      Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6333
      DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,9.00.0001.0021
      WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
      Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6333
      DivX Demux Filter,0x00600000,0,3,DirectShowDemuxFilter.dll,1.00.0003.0136
      ATI MPEG Video Encoder,0x00200000,1,1,atimpenc.dll,11.06.0000.10707
      Haali Video Renderer,0x00200000,1,0,dxr.dll,
      RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0001
      Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0030
      Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,3.02.0000.0030
      DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.03.0000.0048
      Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,3.02.0000.0030
      ATI MPEG Multiplexer,0x00200000,2,1,atimpenc.dll,11.06.0000.10707
      WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5262
      DivX Demux Filter (Unrestricted Edition),0x00200000,0,3,DirectShowDemuxFilter.dll,1.00.0003.0136
      WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,3.02.0000.0030
      VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
      Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
      Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0030
      MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
      File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
      ATI Video Scaler Filter,0x00200000,1,1,atimpenc.dll,11.06.0000.10707
      Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,3.02.0000.0030
      Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.10.0175.0000
      Nero AAC Parser,0x00400000,1,1,NeAudio.ax,3.02.0000.0030
      WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
      DirectVobSub,0x00200000,2,1,vsfilter.dll,2.39.0005.0003
      RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
      DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,2.39.0005.0003
      DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169
      MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
      Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169
      Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.10.0175.0000
      Nero Splitter,0x00600000,1,3,NeSplitter.ax,3.02.0000.0030
      AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6333
      .RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5262
      Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,3.02.0000.0030
      WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
      MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
      DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
      Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
      Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5262
      ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.01.3530.0000
      Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,7.01.0000.3055
      ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
      ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
      ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
      ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
      ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
      ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
      ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262
      9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
      Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,3.02.0000.0030
      Nero Video Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0030
      Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.6404
      Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.6404
      WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
      MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
      IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
      WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,3.02.0000.0030
      MPC - FLV Source (Gabest),0x00600000,0,0,FLVSplitter.ax,1.03.2116.0000
      StreamBufferSource,0x00200000,0,0,sbe.dll,
      Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
      Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169
      Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,3.02.0000.0030
      AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
      Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6333
      MPC - MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.03.2116.0000
      QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6333
      Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
      MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
      Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
      Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
      File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6333
      XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5262
      Nero File Source,0x00200000,0,1,NeFileSrc.ax,3.02.0000.0030
      Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0030
      Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,3.02.0000.0030
      ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.01.3530.0000
      Video Source,0x00200000,0,1,wmprevu.dll,7.01.0000.3055
      MPC - Mpeg Splitter (Gabest),0x00400001,1,1,MpegSplitter.ax,1.03.2116.0000
      Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0030
      MainConcept Stream Parser,0x00400000,1,2,mc_demux_mp2_ds.ax,9.06.0008.8663
      ATI Video Rotation Filter,0x00200000,1,1,atimpenc.dll,11.06.0000.10707
      Nero Digital Parser,0x00600000,0,3,NDParser.ax,3.02.0000.0030
      RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0001
      AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
      MPC - MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.03.2116.0000
      CyberLink QuickTime Source Filter,0x00200000,0,2,QuickTime.ax,1.00.0000.1016
      Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6333
      File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6333
      File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6333
      WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Nero Frame Capture,0x00200000,1,1,NeCapture.ax,3.02.0000.0030
      WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0030
      Haali Video Sink,0x00200000,1,0,splitter.ax,1.10.0175.0000
      Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
      Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
      Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,3.02.0000.0030
      QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
      ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
      MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6333
      Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
      Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
      WDM Streaming Tee/Splitter Devices:
      Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.5512
      WDM Streaming Data Transforms:
      Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
      Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
      Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
      Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
      Video Compressors:
      WMVideo Encoder DMO,0x00600800,1,1,,
      WMVideo8 Encoder DMO,0x00600800,1,1,,
      MSScreen encoder DMO,0x00600800,1,1,,
      WMVideo9 Encoder DMO,0x00600800,1,1,,
      MSScreen 9 encoder DMO,0x00600800,1,1,,
      DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
      ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.01.3530.0000
      Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
      MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6333
      Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0030
      Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
      DivX 6.9.2 Codec (1 Logical CPU),0x00200000,1,1,qcap.dll,6.05.2600.5512
      Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
      DivX 6.9.2 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.5512
      Audio Compressors:
      WMA Voice Encoder DMO,0x00600800,1,1,,
      WM Speech Encoder DMO,0x00600800,1,1,,
      WMAudio Encoder DMO,0x00600800,1,1,,
      IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6333
      IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
      Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
      ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6333
      DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.6333
      Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6333
      Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6333
      GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6333
      Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.6333
      CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
      CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
      MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6333
      Audio Capture Sources:
      Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.5512
      Midi Renderers:
      Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
      Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.6333
      WDM Streaming Capture Devices:
      Realtek AC97 Audio,0x00000000,0,0,,
      PC Camera (6025 VGA),0x00200000,0,1,,5.03.2600.5512
      WDM Streaming Rendering Devices:
      BDA Rendering Filters:
      BDA IP Sink,0x00200000,1,1,,5.03.2600.5512
      Video Capture Sources:
      BDA Transport Information Renderers:
      MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
      WDM Streaming Mixer Devices:
      Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
      BDA CP/CA Filters:
      Decrypt/Tag,0x00600000,1,0,encdec.dll,
      Encrypt/Tag,0x00200000,0,0,encdec.dll,
      XDS Codec,0x00200000,0,0,encdec.dll,
      WDM Streaming Communication Transforms:
      Audio Renderers:
      Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.6333
      Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
      Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.6333
      DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.6333
      WDM Streaming System Devices:
      Realtek AC97 Audio,0x00200000,17,2,,5.03.2600.5512
      BDA Receiver Component:
      BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
        • 1. Re: flashplayer problems
          pwillener Level 8
          Not quite; see http://forums.adobe.com/thread/945765
          After you installed the latest driver, try turning hardware acceleration back on.
          • 2. Re: flashplayer problems
            ghoshy2010 Level 1
            Hi pat Willener.   with or with out acceleration it makes no difference, the only way I can explain it is the video comes through fine but it is as if the audio is using all my computer resources, just like when a scanner scans a computer and slows things down but with this it lasts a couple of seconds then I get 2 second of normal audion followed by a lag then audio and then lag all the way through the pre-recorded video, dosn't affect just that even when I play music through windows media or another stand alone player the same thing, I have a level 2 computer tech from manchester university so I know most thing's and dont claim to be a proffessional, but the sound has me a bit stumped, I have uninstalled drivers and codec's even uninstalled the driver for the ethernet and made sure no after effects in registry and still nothing, even the sound card was uninstalled and reinstalled and all I can assume it to be is hardware failure or a corupted operating system,  but didnt have this before updating flash, so will just keep at sooner or later I will find the answer and have a chocolate biscuit for being a good boy at finding the answer lol
            • 3. Re: flashplayer problems
              pwillener Level 8
              I have tried to read that one sentence post several times; it's impossible to understand!
              So one question: did you update your graphics driver to the latest available (April 2013)?
              • 4. Re: flashplayer problems
                ghoshy2010 Level 1
                Hi Pat,  for my graphics card has the latest driver for it,  but like I said if I find the answer I will have a chocolate buscuit and I found the answer why the sound and graphics can be affected in the new flash player, it seems for some reason the IDE names on the drives gets changed for some reason, when I looked at my hardware under system pref's with device manager the name on one of my drives had been changed causing the drive to switch from DMA to PIO a slower form of file transfer but more stable, so I changed the name back by updating the driver and not allowing windows to decide the driver for me and I have been able to watch video and prematch even live media with no problem's, so may be you could put this forward as a possible answer for other user's it may not work for everyone as theres may be hardware faulure but it might help some,  hope its useful just remember where the answer came from ,
