1. Re: Inconsistent placement of anchored text frame in data merge document
Peter Spier Aug 19, 2013 7:08 AM (in response to alanomaly)You didn't say what version of ID, or whter a single or multiple record per page merge, but the Preview is known to be buggy for multiple records since CS5 and might be for single records as well.
I have an annual directory that is built by data merge with one section in each listing as an anchored frame, and I've never had a problem, but it's not as complex as your description, nor do I ever merge to PDF (though I've heard here from several users that it's more reliable).
One thing you might want to try is merging without the preview step, but do it from a "fresh" file by copying and pasting your placeholders into a new document. If the problem is with the preview it seems that it "infects" the file and even merging without touching the preview button may not work.
2. Re: Inconsistent placement of anchored text frame in data merge document
alanomaly Aug 19, 2013 7:19 AM (in response to Peter Spier)This is on CS6 (8.0.1) on Mac.
Interesting idea about the preview 'infecting' the file. I'm sure the export behaviour changed, as I've exported PDFs from this file 10s of times before without seeing the extra 4mm (which breaks the layout) - although I've also used the data merge preview 100s of times. Will keep the new file idea in mind if this comes up again.
