2 Replies Latest reply on Aug 23, 2013 12:41 AM by Graham Jones Design
    Is there a way to turn off indesign's ability to select through the transparent part of a frame?
    Graham Jones Design
      ID is driving me crazy with either deselecting a frame or selecting the object behind the frame.
      What do I mean?
      Well if you have say for example a couple of lines of text outlined and you then select the text to move it, if you don't get your selection tool bang of the outlined text when you click and hold to move it, iD selects through the frame (because that part of the frame is transparent) so it in effect, deselects the object, this is a real problem if the outlined text is quite fine, which means the majority of the frame is transparent.
      Why does ID do this, if you wanted to deselect the object you would click away from the frame or use the keyboard shortcut, or if you wanted select the object below you would use the keyboard shortcut.
      I have lost count of how many times I have had to go back and reselect an object! Am I missing a setting somewhere?
      I'm using the dreaded CC version, no it doesn't stand for Constantly Crashing, it stands for Creative Cloud!
      Thanks Graham.
        • 1. Re: Is there a way to turn off indesign's ability to select through the transparent part of a frame?
          John Mensinger Adobe Community Professional & MVP
          I don't seem to have that problem in CS6. I select/drag the topmost object no matter where I click on it. Can't really speak for whether it changed in CC.
          AFAIK, you can't change any aspects of the default behavior that would help ease your problem, but there are some habits you can develop to make selection easier:
          1. Use layers. With some basic planning, The ability to lock or hide non-target layers can make managing your views, as well as selecting and manipulating objects much easier.
          2. Pay close attention to the cursor. It changes when in position to select an object or move a selected object.
          3. Use the arrow keys to move an object rather than click/drag.
          • 2. Re: Is there a way to turn off indesign's ability to select through the transparent part of a frame?
            Graham Jones Design Level 1
            Hi John,
            Thanks for your answer, you do confirm one point, I didn't think this was happening when I was on CS6, I just couldn't be sure. It looks like Adobe have either missed this fact in CC or even worse, supposedly upgraded it to a better feature, when in reality it is just a nightmare!
            Although your suggestions aren't very useful, thanks anyway, see below.
            Layers: I do use layers all the time, but that won't prevent the deselecting of the object.
            Cursor. I bet you don't need to pay micro-attention to the cursor when just moving an already selected object, extra stress is what it is!
            Arrow Keys. Not very practical, especially when I already have hold of the mouse, plus I lose my smart-guides.
            The solution is for the engineers to fix it, I think I may need to get more proactive with my feedback.
            Thanks Graham.
