4 Replies Latest reply on Aug 19, 2013 2:38 PM by CarlosCanto
    Illustrator: Rename Swatches
    big_smile Level 1
      In Illustrator Javascript, you can use the following to rename layers:
      var doc = app.activeDocument;
      // loop through all layers
      for (var i = 0; i < doc.layers.length; i++) {
      //Set up variables for current and new name
                var currentName = "Unused";
                var newName = "-Unused";
      //Set up Variable to access layer name
                var currentLayer = app.activeDocument.layers[i];
                if (currentLayer.name == currentName) {
                          currentLayer.name = newName;
      Is there anyway to rename colour swatches.
      For example, I have 20 swatches named Yellow -(Keyword). (The keyword is different for each swatch).
      I would like to replace yellow with the word colour1 while replacing the -(keyword) part in tact.
      Is this possible? My swatches are in groups, so I am not sure if it makes it more complicated.
      Thanks!
        • 1. Re: Illustrator: Rename Swatches
          W_J_T Level 4
          Sure you can change swatch names, this snippet will change all swatch names for example.
          for (var i = 0; i < doc.swatches.length; i++) {
              doc.swatches[i].name = "RenamedSwatchName_"+i;
          As for your naming convention you can change the names like you mentioned as well, also within color groups as the example above shows.
          • 2. Re: Illustrator: Rename Swatches
            big_smile Level 1
            Thanks!
            I am a little bit confused. RenamedSwatchName is where I put the new name. But where do I put the existing name of the swatch?
            Also, how do I make only change part of a name.
            E.g.
            Yellow -skin
            Yellow -hair
            Yellow -eyes
            should change to
            colour1 -skin
            colour1 -hair
            colour1 -eyes
            Thanks again. I really do appreciate it!
            • 3. Re: Illustrator: Rename Swatches
              W_J_T Level 4
              You're welcome. The snippet I showed was merely an example demonstrating that "yes" you can change swatch names. For your specific requirement you would need to manipulate and alter the .name string to make the changes. In the example you have shown above you can do something like the following basic example:
              // You can use split/join, or replace for example:
                  // replace "Yellow" with "colour1"
                  doc.swatches[i].name = doc.swatches[i].name.split('Yellow').join('colour1');
                  // doc.swatches[i].name = doc.swatches[i].name.replace('Yellow', 'colour1');
                  // Or if you need case insensitive ie: Yellow, yellow, etc...
                  // doc.swatches[i].name = doc.swatches[i].name.split(/yellow/gi).join('colour1');
                  // doc.swatches[i].name = doc.swatches[i].name.replace(/yellow/gi, 'colour1');
              • 4. Re: Illustrator: Rename Swatches
                CarlosCanto Adobe Community Professional & MVP
                same as above sample from W_J_T, targeting only a swatch group
                //var swatches = app.activeDocument.swatches; // process all swatches
                var swatches = app.activeDocument.swatchGroups["Brights"].getAllSwatches(); // process only targeted swatch group
                for (var i = 0; i < swatches.length; i++) {
                    var currentName = "Yellow";
                    var newName = "colour1";
                    swatches[i].name = swatches[i].name.replace (currentName, newName);
                2 people found this helpful
