2 Replies Latest reply on Jan 14, 2008 9:40 AM by Help_Solutions
    WebHelp "standard" window size
    maniac9999 Level 1
      Hey everyone,
      We're in the process of redesigning our skins for a few WebHelp projects. In the process of creating new skin prototypes, we've discovered that almost every application we're potentially designing for has a different help window size - no one ever declared a "standard" help window size for all web applications, and consequently, they're very inconsistent. We have everything from 648 wide by 554 high to 500 by 500 to 750 by 650. We would like to declare a standard help window size for all web applications so that we can state "Skins are optimized for a XXX by XXX help window size". I know that a user can shrink or expand the help window, but I don't want that to dictate how we design our skins. The only way to be completely "safe", it seems, is to create a background image that only uses a solid color (boring).
      What do other people do for a web help window size? Is there a recommended standard size?
      Jim
        • 1. Re: WebHelp "standard" window size
          RoboColum(n) Level 5
          Hi Jim.
          It is horses for courses really. I bet everyone has a different window size. I'd say it depends on what you are displaying. TOC/Index/Search/Glossary tabs, browse sequences, topic content (e.g. images), etc. etc. would all have a bearing on the best size for the window. My advice? Pick a "standard" and go with it.
          • 2. WebHelp "standard" window size
            Help_Solutions Level 1
            Hi Jim,
            We always try to avoid overwhelming the user and make the help window relative to the application window. This is one advantage of using CSH to call up the topic window and the initial call to hide the TOC/Index and Search. If the help window hides the application, the user may find it hard to refer between the two.
            As you rightly say, the user should always have the ability to change the size of the window if they desire.
            You may also like to consider the average computer screen size used by your users. Some companies issue everyone with 19in screens or higher, others are not so generous.
            I know this is not much help as it does not give you a direct help window size, but there is a lot to consider if you need to come up with a standard. Don't forget to also specify standard for images that will be included in the help system. You may want to consider a maximum width for screen shots for example as these may be hidden if they do not comfortable fit in the help topic window.
            It is also something to discuss with the developers.
            Just as a guide, I'm currently working on a project that displays the help window at 600*500. This does not hide the application window and gives the user the ability to toggle between the application and help. It is good to give the user a bit of control.
            Hope this helps and good luck
            Kind Regards
            Craig
