0 Replies Latest reply on Jan 14, 2008 5:34 AM by Mark.P.
    Annotation on bar chart needs a little help
    Mark.P.
      I'm placing a small button at some of the bars in the barChart
      depending on the data using annotationElements. The x axis is set to
      0 and y is set to each bar in the cart. Everything works just great,
      but in some cases the bar will span the entire length of the chart so
      the button falls on top of a bar. When this happens, if you click on
      the button you get a pop-up window from that button (good), and a pop-
      up from an itemClick from the bar (bad). Is there a way to make it so
      only the button event works and not the bar when clicking a button
      that falls on top of a bar?
      Mark
