0 Replies Latest reply on Aug 20, 2013 6:28 PM by greentea87
    Additional comments in generated XML
    greentea87 Level 1
      On click of submit button in my PDF form, it will return to my webapp the generated XML from the form. Recently there is a case where we received extra XML comments being added into the XML (Right after the XML root element) . The comments are as following:
      If you filled in a form:
          This file contains data that was entered into a form.
          It is not the form itself.
      If you receive this data file:
          Please follow the directions below to process this data file using
          Adobe Acrobat Professional 7
      **To view the completed form:
          1) Save this data file to your computer.
          2) Open a blank copy of the original PDF form that the form filler
      completed in order to generate this data file.
          3) In Acrobat, choose Advanced > Forms > Import Data to Current Form
             and browse for this data file.
          4) You will see the form with the data in it.
          5) To save a copy of the form with the data in it, choose File > Save As
             and save the file.
      **To create a spreadsheet from one or more form data files you have received:
          1) Save the data files to a place on your computer, giving each file a
             unique name and making sure not to delete the '.xml' file extension.
          2) In Acrobat, choose File > Form Data > Create Spreadsheet from Data Files.
          3) Click the 'Add Files' button to chose the data files.
          4) After the data files are added, click the 'Create Spreadsheet' button
             to create a Spreadsheet that contains data from selected data files.
      I was wondering what could be the possible cause of this.
