1 Reply Latest reply on Aug 21, 2013 7:19 PM by MW Design
    Creating a pdf with user selectable images?
    zigmenthotep
      Hello, I'm quite new to indesign and need some help. I really hate to be that guy saying "quick someone fix my problem for me" but I'm signifigantly behind schedual and this is holding me up.
      Basically, I need some way to alow a used to select from and print up to 8 of around 60 images. An ideal situation would be somehow being able to select images from dropdown lists, but as I said I'm behind schedual and no longer care if it's pretty or intuitive as long as it works.
      If anyone can offer some advice on acomlishing this I would be forever greatful. Oh, I'm using cs6
        • 1. Re: Creating a pdf with user selectable images?
          MW Design Level 5
          I would make a web site for this. I might use a PDF for showing off the options/images and point them to the web site.
          That said, you can use images on buttons, or layers, and show/hide the images using javascript. What is displayed is what will print. I would put the request for aid into the Acrobat forum as someone may have already scripted this. I probably wouldn't use ID for more than the static elements to make the PDF pretty. Then use Acrobat to add images and script it.
          Mike
