1 Reply Latest reply on Aug 27, 2013 8:46 AM by Tom Ruark
    Getting weird error: "General Photoshop error occurred".
    _VG
      Hi Guys,
      I am trying to get the info(font, color, alignment etc.)  of text kind layer in Photoshop CC. My script is as follows,
      var textLayer = activeDocument.activeLayer.textItem;
      var fontName = textLayer.font;
      try{
           var textColor = "R: " + textLayer.color.rgb.red + " G: " + textLayer.color.rgb.green + " B: " + textLayer.color.rgb.blue;
      catch(e){alert(e);}
      try
           var textAlignment = textLayer.justification.toString();
      catch(e){alert(e);}
      On setting the color value R - 0, B - 0 and G - 0 or alignment 'Left' and create a text layer after this. I encountered an error
      "Error: General Photshop error occurred. This functionality may not be available in this version of Photoshop.
           - <no additional information available> "
      If I set some other color value and other alignment and create the text and get its info, script works fine.
      Or If I change the values and revert it back to 'Left' alignment and R-0, B-0 and G-0 then I am able to get the values with the above script.
      I get this error at first time only and after that script works fine
      I also run this script with CS5 version, Its working fine there. But I don't know why I am getting this error in CC version.
      Am I doing something wrong here or Is it some issue with Photoshop CC.
      Any help would be appriciated.
      Thanks..
        • 1. Re: Getting weird error: "General Photoshop error occurred".
          Tom Ruark Adobe Employee
          Is your text layer using a layer style? If so, this routine should find the font and color in use.
          var fontsInUse = [];
          var colorsInUse = [];
          if ( documents.length > 0 ) {
              GetFontUsage( activeDocument.layers, fontsInUse );
                    alert( fontsInUse );
              GetColorUsage( activeDocument.layers, colorsInUse );
                    alert( colorsInUse );
          } else {
                    alert( "Please open a document." );
          function GetFontUsage( l, f ) {
              for ( var i = 0; i < l.length; i++ ) {
                  if ( l[i].typename == "LayerSet" ) {
                      GetFontUsage( l[i].layers, f );
                  } else if ( l[i].typename == "ArtLayer" && l[i].kind == LayerKind.TEXT  ) {
                      try {
                          f.push( l[i].textItem.font );
                      catch(e) {
                          f.push( GetFontUsageFromDescriptor( l[i] ) );
          function GetColorUsage( l, f ) {
                      try {
                          f.push( Math.round(l[i].textItem.color.rgb.red) + ":" +
                                  Math.round(l[i].textItem.color.rgb.green) + ":" +
                                  Math.round(l[i].textItem.color.rgb.blue));
                      catch(e) {
                          f.push( GetColorUsageFromDescriptor( l[i] ) );
          // text layer probably has a layer style
          // we will try to select the layer
          // pull the descriptor
          // and see if we can find a font
          function GetFontUsageFromDescriptor( l ) {
              var layerFontName = "";
              var lastActive = activeDocument.activeLayer;
              activeDocument.activeLayer = l;
              var ktextKeyStr = stringIDToTypeID("textKey");
                    var ref = new ActionReference();
                    ref.putProperty(charIDToTypeID('Prpr'), ktextKeyStr);
                    ref.putEnumerated(charIDToTypeID('Lyr '), charIDToTypeID('Ordn'),
        charIDToTypeID('Trgt'));
                    var desc = executeActionGet(ref);
                    if ( desc.hasKey( ktextKeyStr ) ) {
                              var descText = desc.getObjectValue( ktextKeyStr );
                  var kparagraphStyleRangeStr = stringIDToTypeID( "paragraphStyleRange" );
                  if ( descText.hasKey( kparagraphStyleRangeStr ) ) {
                      var paraList = descText.getList(  kparagraphStyleRangeStr );
                      var kparagraphStyleStr = stringIDToTypeID("paragraphStyle");
                      var paraDesc = paraList.getObjectValue( 0 );
                      if ( paraDesc.hasKey( kparagraphStyleStr ) ) {
                          var paraStyle = paraDesc.getObjectValue( kparagraphStyleStr );
                          var kdefaultStyleStr = stringIDToTypeID("defaultStyle");
                          if ( paraStyle.hasKey( kdefaultStyleStr ) ) {
                              var defStyle = paraStyle.getObjectValue( kdefaultStyleStr );
                              var kfontPostScriptNameStr = stringIDToTypeID("fontPostScriptName");
                              if ( defStyle.hasKey( kfontPostScriptNameStr ) ) {
                                  layerFontName = defStyle.getString( kfontPostScriptNameStr );
              activeDocument.activeLayer = lastActive;
              return layerFontName;
          // and see if we can find a color
          function GetColorUsageFromDescriptor( l ) {
              var layerColor = "";
                              var kColorStr = stringIDToTypeID("color");
                              if ( defStyle.hasKey( kColorStr ) ) {
                                  var colorDesc = defStyle.getObjectValue( kColorStr );
                                  layerColor += Math.round( colorDesc.getInteger( stringIDToTypeID("red" ) ) ) + ":";
                                  layerColor += Math.round( colorDesc.getInteger( stringIDToTypeID("green" ) ) ) + ":";
                                  layerColor += Math.round( colorDesc.getInteger( stringIDToTypeID("blue" ) ) );
              return layerColor;
