5 Replies Latest reply on Aug 22, 2013 6:57 AM by greenrookie
    Page Exporter Utility script help
    Billjamesg
      I am trying to adapt a Page Exporter Script which converts a multi page InDesign file into single PDF's, it is a brilliant script!
      Anyway, I can't figure out as I am a very novice scripter, can anyone help if I post the script up and describe what I am trying to achieve?
      B
        • 1. Re: Page Exporter Utility script help
          DaveSofTypefi Level 2
          Whose script is it? Do you have permission to republish? Can the person who wrote the original help you?
          Dave
          • 2. Re: Page Exporter Utility script help
            Billjamesg Level 1
            I'm not totally sure where I got it from or who orinially wrote it, but it was an open source website, it may have been InDesign Secrets.
            • 3. Re: Page Exporter Utility script help
              greenrookie Level 2
              Might it be Scott Zanelli's PageExporterUtility.
              — GNU general public license.
              • 4. Re: Page Exporter Utility script help
                Billjamesg Level 1
                That rings a bell.
                Do you know how I can get hold of him to see if he would be so kind as to help me out?
                • 5. Re: Page Exporter Utility script help
                  greenrookie Level 2
                  I don't sorry, perhaps a member here could. According to the license:
                  2. You may modify your copy or copies of the Program or any portion
                  of it, thus forming a work based on the Program, and copy and
                  distribute such modifications or work under the terms of Section 1
                  above, provided that you also meet all of these conditions:
                      a) You must cause the modified files to carry prominent notices
                      stating that you changed the files and the date of any change.
                      b) You must cause any work that you distribute or publish, that in
                      whole or in part contains or is derived from the Program or any
                      part thereof, to be licensed as a whole at no charge to all third
                      parties under the terms of this License.
                      c) If the modified program normally reads commands interactively
                      when run, you must cause it, when started running for such
                      interactive use in the most ordinary way, to print or display an
                      announcement including an appropriate copyright notice and a
                      notice that there is no warranty (or else, saying that you provide
                      a warranty) and that users may redistribute the program under
                      these conditions, and telling the user how to view a copy of this
                      License.  (Exception: if the Program itself is interactive but
                      does not normally print such an announcement, your work based on
                      the Program is not required to print an announcement.)
