5 Replies Latest reply on Feb 12, 2008 4:44 PM by ignite
    DataGrid, itemRenderer, viewStacks
    ignite
      I am using an inline itemRenderer for an image on a Datagrid which rests in a viewStack. However, if the Datagrid is not in the first index of the viewStack the itemRenderer will not load. I've tried changing the creationPolicy of the viewStack with no avail. Any ideas?
      Ruben
        • 1. Re: DataGrid, itemRenderer, viewStacks
          tpeter2
          Did you ever get a solution to this problem? I too, am having similar issues when using a datagrid in a viewstack.
          Terra
          • 2. Re: DataGrid, itemRenderer, viewStacks
            Arty13
            Can either of you be more specifc with your issue? Or provide any sample code?
            Art
            • 3. Re: DataGrid, itemRenderer, viewStacks
              tpeter2 Level 1
              What I am trying to do is create a ViewStack that contains two DataGrid's. The first Datagrid will only contain 5 rows of data; the second will contain multiple lines, thus requiring a vertical scroll bar. When I trigger an event to show the second DataGrid the vertical scroll bar does not allow me to scroll past a certain point. It seems that the second DataGrid in the ViewStack inherits the properties from the first one.
              Here's a sample:
              <mx:ViewStack id="gridVS" width="100%" height="100%" creationPolicy="all">
              <mx:VBox width="100%" height="100%" verticalScrollPolicy="off" horizontalScrollPolicy="off">
              <mx:DataGrid id="milestoneGrid" height="100%" styleName="myDataGrid" width="100%" dataProvider="{statusData}" rowCount="8" variableRowHeight="true" enabled="false">
              <mx:columns>
              <mx:Array>
              <mx:DataGridColumn dataField="itemLabel" headerText="Milestone" width="120"/>
              <mx:DataGridColumn dataField="schedDate" headerText="Scheduled Start Date" width="120"/>
              <mx:DataGridColumn dataField="startDate" headerText="Started"/>
              <mx:DataGridColumn dataField="status" headerText="Status"/> <mx:DataGridColumn dataField="endDate" headerText="Completed"/>
              </mx:Array>
              </mx:columns>
              </mx:DataGrid>
              </mx:VBox>
              <mx:VBox width="100%" height="100%">
              <mx:DataGrid id="areaGrid" styleName="myDataGrid" width="100%" height="100%" selectable="true" rowCount="8" dataProvider="{statusData}" enabled="true" editable="false" variableRowHeight="true" >
              <mx:columns>
              <mx:Array>
              <mx:DataGridColumn dataField="itemLabel" headerText="Area" width="270" wordWrap="true"/>
              <mx:DataGridColumn dataField="user" headerText="Run By"/>
              </mx:Array>
              </mx:columns>
              </mx:DataGrid>
              </mx:VBox>
              </mx:ViewStack>
              • 4. Re: DataGrid, itemRenderer, viewStacks
                Gregory Lafrance Level 6
                In the following code (modified version of yours) if you remove enabled="false" from the milestoneGrid datagrid it seems to work:
                <?xml version="1.0"?>
                <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml"
                height="200">
                <mx:ArrayCollection id="statusData">
                <mx:Object>
                <mx:itemLabel>M1</mx:itemLabel>
                <mx:schedDate>01/01/2008</mx:schedDate>
                <mx:startDate>01/01/2008</mx:startDate>
                <mx:endDate>01/10/2008</mx:endDate>
                <mx:user>Bob Smith</mx:user>
                <mx:status>overdue</mx:status>
                </mx:Object>
                <mx:Object>
                <mx:itemLabel>M2</mx:itemLabel>
                </mx:Object>
                <mx:Object>
                <mx:itemLabel>M3</mx:itemLabel>
                </mx:Object>
                <mx:Object>
                <mx:itemLabel>M4</mx:itemLabel>
                </mx:Object>
                <mx:Object>
                <mx:itemLabel>M5</mx:itemLabel>
                </mx:Object>
                <mx:Object>
                <mx:itemLabel>M6</mx:itemLabel>
                </mx:Object>
                <mx:Object>
                <mx:itemLabel>M7</mx:itemLabel>
                </mx:Object>
                <mx:Object>
                <mx:itemLabel>M8</mx:itemLabel>
                </mx:Object>
                </mx:ArrayCollection>
                <mx:HBox borderStyle="solid">
                <mx:Button label="Datagrid One"
                click="gridVS.selectedChild=dg1;"/>
                <mx:Button label="Datagrid Two"
                click="gridVS.selectedChild=dg2;"/>
                </mx:HBox>
                <mx:VBox id="dg1" width="100%" height="100%"
                <mx:columns>
                <mx:Array>
                </mx:Array>
                </mx:columns>
                </mx:DataGrid>
                </mx:VBox>
                <mx:VBox id="dg2" width="100%" height="100%">
                <mx:columns>
                <mx:Array>
                </mx:Array>
                </mx:columns>
                </mx:DataGrid>
                </mx:VBox>
                </mx:ViewStack>
                </mx:Application>
                • 5. Re: DataGrid, itemRenderer, viewStacks
                  ignite Level 1
                  I don't know if you are having the same issue I had. I fixed my issue by changing the DataGridColumn width. For some reason when the DataGrid was placed in a viewstack the width was rendered differently for each column. The actual itemrenderer was showing up fine, but the column was not visible.
