9 Replies Latest reply on Aug 24, 2013 2:09 AM by bastieneichenberger
    link item space return string in language
    bastieneichenberger Level 1
      Hi all,
      I'm trying to write a function who return true if the link image in indesign is in bitmap (black and white) color space.
      My function works but only if the indesign language is in english.
      I explain, the image.space property return "black and white" in english and "noir et blanc" in french.
      How I can do to use this function with other indesign versions?
      #target indesign
      var doc = app.activeDocument;
      var array_all_links = doc.links;
      for(var i = 0; i<array_all_links.length; i++){
          is_image_bitmap (array_all_links[i] );
      function is_image_bitmap(link_item){
          var image = link_item.parent;
          if (image.constructor.name == "Image") {
              if(image.space == "Black and White"){ // this line doesn't work in french because the return value is noir et blanc…
                  alert("ok");
