29 Replies Latest reply on Jan 16, 2014 4:16 PM by Lee Ramsay
    Extension Manager CC not loading under User account on Mac Mountain Lion
    tenorphoto Level 1
      HI
      I am trying to install a DWUser add in called EasyRotator into Dreamweaver CC. I cannot get Extnesion Manager to launch properly though. The Manager window comes up but the little white clock icon simply spins around for ages then finally when it stops it does not list any applications despite the fact that I have the full Master Collection installed.  I managed to get it to load properly under my Admin account but it did not install the add in for all users for some reason (I was not even offered any option about that - when I installed this add in to Dreamweaver CS6 with the CS6 Extension Manager I was given the option of installing for only  me or all users).
      When I log in under my non-admin user account (I use a separate admin account as I was advised to do this for security reasons) I  launch Extension manager CC but it takes forever to launch and when it does it lists no Adobe applications, hence I cannot install the add in to Dreamweaver for this account.
      I am having to edit the easyrotator in Dreamweaver CS6 as that works! Why does CC not work?
      Oh and BTW when I try to close the Extension Manger CC it fails to respond and I have to force quit it.
      Any help greatly appreciated.
      D
        • 1. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
          tenorphoto Level 1
          Still no luck getting Extension Manager CC to launch and list my Apps let alone allow me to actually install and extensions. Anyone out there having similar problems? Anyone with a fix PLEASE.
          Ta
          D
          • 2. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
            Yuanyuan Liu Level 1
            Do you install the Extension Manager CC  and Dreamweaver CC from creative cloud? If you installed them from creative cloud, please ensure that they are up-to-date. You can launch Extension Manager CC by admin account, right? Please tell me what products it lists.
            • 3. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
              Please check whether you have write permission to "/Library/Application Support/Adobe/Extension Manager CC/Configuration/DB" folder. If not, please grant youself permission then try to launch Extension Manager.
              • 4. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                tenorphoto Level 1
                I installed all the Master Collection CC apps from Creative Cloud and all apps are showing as up to date. Extension Manager CC in Admin account lists
                Dreamweaver CC
                Flash CC
                Illustrator CC
                InCopy CC
                InDesign CC
                Photoshop CC
                Prelude CC
                Premiere Pro CC
                Others
                However it does not list the EasyRotator add in under Dreamweaver although I have installed it several times now. If I try to install it again the installing extension wheel spins but the installation does not take place.
                • 5. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                  tenorphoto Level 1
                  This folder exists only in the Library on the root directory on my SSD, it has permission for everyone to read and write. Under my User account Library Extension Manager CC does not appear in the Adobe folder in Application Support folder.
                  • 6. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                    please get log files as the following steps:
                    1. Create a file called 'ExManCoreLibLog.YES' and place it in the location:
                    MAC: /Users/<username>/Library/Application Support/Adobe/Extension Manager CC/Log/ExManCoreLibLog.YES
                    2. Reproduce the issue
                    3. The logs files are generated in the location:
                    4. send the log files to exman.beijing@gmail.com
                    • 7. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                      tenorphoto Level 1
                      Hi Yuanyuan
                      thanks for your help. I am trying to follow your instructions but as you see from this screen shot, there is no Extension Manager CC folder in the location you list under my user account, it only appears under my Admin account. please see attached screen shots:
                      Also how do I create a file called 'ExManCoreLibLog.YES
                      I will wait to hear from you on this.
                      D
                      • 8. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                        tenorphoto Level 1
                        Hi there folks,
                        I am still hoping someone here can get a fix for my issue as it remains unsolved. Anyone want to wade in with some help PLEASE.
                        Here is the contents of the error report that I get when Extension Manager CC crashes on exit under my non admin user account:
                        Process:         Adobe Extension Manager CC [566]
                        Path:            /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/Adobe Extension Manager CC
                        Identifier:      com.adobe.ExtensionManager
                        Version:         7.0.1.17 (7.0.1.17)
                        Code Type:       X86 (Native)
                        Parent Process:  launchd [356]
                        User ID:         502
                        Date/Time:       2013-08-26 12:58:35.977 +0100
                        OS Version:      Mac OS X 10.8.4 (12E55)
                        Report Version:  10
                        Interval Since Last Report:          132547 sec
                        Crashes Since Last Report:           4
                        Per-App Interval Since Last Report:  4871 sec
                        Per-App Crashes Since Last Report:   2
                        Anonymous UUID:                      189E1B0D-CBD2-D296-CD8C-15232A3FFEB5
                        Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                        Exception Type:  EXC_BAD_ACCESS (SIGBUS)
                        Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
                        VM Regions Near 0:
                        --> __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/Adobe Extension Manager CC
                            __TEXT                 0000000000001000-00000000000d8000 [  860K] r-x/rwx SM=COW  /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/Adobe Extension Manager CC
                        Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                        0   ???                                     0000000000 0 + 0
                        1   com.adobe.ape.engine                    0x063dee8d APXGetHostAPI + 3708637
                        2   com.adobe.ape.engine                    0x064913e9 APXGetHostAPI + 4439097
                        3   com.adobe.ape.engine                    0x0649c246 APXGetHostAPI + 4483734
                        4   com.adobe.ape.engine                    0x0649c8b4 APXGetHostAPI + 4485380
                        5   com.adobe.ape.engine                    0x064f0888 SWFLPlayer_Initialize + 9960
                        6   com.apple.CoreFoundation                0x9284204f __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
                        7   com.apple.CoreFoundation                0x92841a79 __CFRunLoopDoSources0 + 233
                        8   com.apple.CoreFoundation                0x92867826 __CFRunLoopRun + 934
                        9   com.apple.CoreFoundation                0x9286701a CFRunLoopRunSpecific + 378
                        10  com.apple.CoreFoundation                0x92866e8b CFRunLoopRunInMode + 123
                        11  com.apple.HIToolbox                     0x90316f5a RunCurrentEventLoopInMode + 242
                        12  com.apple.HIToolbox                     0x90316cc9 ReceiveNextEventCommon + 374
                        13  com.apple.HIToolbox                     0x90316b44 BlockUntilNextEventMatchingListInMode + 88
                        14  com.apple.AppKit                        0x92dd793a _DPSNextEvent + 724
                        15  com.apple.AppKit                        0x92dd716c -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
                        16  com.apple.AppKit                        0x92dcd5cc -[NSApplication run] + 855
                        17  com.apple.AppKit                        0x92d705f6 NSApplicationMain + 1053
                        18  com.adobe.ExtensionManager              0x0004ef7b main + 1193
                        19  com.adobe.ExtensionManager              0x000025c5 start + 53
                        Thread 1:
                        0   libsystem_kernel.dylib                  0x96f6c0ee __workq_kernreturn + 10
                        1   libsystem_c.dylib                       0x99fe60ac _pthread_workq_return + 45
                        2   libsystem_c.dylib                       0x99fe5e79 _pthread_wqthread + 448
                        3   libsystem_c.dylib                       0x99fcdd2a start_wqthread + 30
                        Thread 2:: Dispatch queue: com.apple.libdispatch-manager
                        0   libsystem_kernel.dylib                  0x96f6c9ae kevent + 10
                        1   libdispatch.dylib                       0x9490ec71 _dispatch_mgr_invoke + 993
                        2   libdispatch.dylib                       0x9490e7a9 _dispatch_mgr_thread + 53
                        Thread 3:
                        Thread 4:
                        Thread 5:
                        Thread 6:
                        0   libsystem_kernel.dylib                  0x96f698e6 mach_wait_until + 10
                        1   libsystem_c.dylib                       0x9a074c10 nanosleep + 375
                        2   com.adobe.ExtensionManager              0x00083c09 ScObjects::Thread::sleep(unsigned int) + 143
                        3   com.adobe.ExtensionManager              0x00083c69 ScObjects::Thread::wait(unsigned int) + 23
                        4   com.adobe.ExtensionManager              0x0007b4b6 ScObjects::BridgeTalkThread::run() + 332
                        5   com.adobe.ExtensionManager              0x0008408f ScObjects::Thread::go(void*) + 239
                        6   libsystem_c.dylib                       0x99fe35b7 _pthread_start + 344
                        7   libsystem_c.dylib                       0x99fcdd4e thread_start + 34
                        Thread 7:
                        0   libsystem_kernel.dylib                  0x96f6b8e2 __psynch_cvwait + 10
                        1   libsystem_c.dylib                       0x99fe8280 _pthread_cond_wait + 833
                        2   libsystem_c.dylib                       0x9a06e095 pthread_cond_wait$UNIX2003 + 71
                        3   com.adobe.ape.engine                    0x062d889f APXGetHostAPI + 2633967
                        4   com.adobe.ape.engine                    0x06069d9f APXGetHostAPI + 83439
                        5   com.adobe.ape.engine                    0x062d898e APXGetHostAPI + 2634206
                        6   com.adobe.ape.engine                    0x062d89f7 APXGetHostAPI + 2634311
                        7   com.adobe.ape.engine                    0x062d8b16 APXGetHostAPI + 2634598
                        8   libsystem_c.dylib                       0x99fe35b7 _pthread_start + 344
                        9   libsystem_c.dylib                       0x99fcdd4e thread_start + 34
                        Thread 8:
                        Thread 9:
                        0   libsystem_kernel.dylib                  0x96f697d2 mach_msg_trap + 10
                        1   libsystem_kernel.dylib                  0x96f68cb0 mach_msg + 68
                        2   com.apple.CoreFoundation                0x92861f79 __CFRunLoopServiceMachPort + 185
                        3   com.apple.CoreFoundation                0x9286795f __CFRunLoopRun + 1247
                        4   com.apple.CoreFoundation                0x9286701a CFRunLoopRunSpecific + 378
                        5   com.apple.CoreFoundation                0x92876ab1 CFRunLoopRun + 129
                        6   com.apple.DVCPROHDMuxer                 0x095cb98f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
                        7   libsystem_c.dylib                       0x99fe35b7 _pthread_start + 344
                        8   libsystem_c.dylib                       0x99fcdd4e thread_start + 34
                        Thread 10:
                        1   libsystem_c.dylib                       0x99fe82e9 _pthread_cond_wait + 938
                        2   libsystem_c.dylib                       0x99fe8572 pthread_cond_timedwait_relative_np + 47
                        3   com.adobe.ape.engine                    0x062d8867 APXGetHostAPI + 2633911
                        4   com.adobe.ape.engine                    0x062f1a5e APXGetHostAPI + 2736814
                        Thread 11:
                        4   com.adobe.ape.engine                    0x06467028 APXGetHostAPI + 4266104
                        Thread 12:
                        0   libExManCoreLib.dylib                   0x001fc870 std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::~_Rb_tree() + 0
                        1   libExManCoreLib.dylib                   0x00810610 Poco::TempFileCollector::~TempFileCollector() + 126
                        2   libExManCoreLib.dylib                   0x0081017e __tcf_0 + 26
                        3   libsystem_c.dylib                       0x9a01debf __cxa_finalize + 184
                        4   libsystem_c.dylib                       0x9a020db9 exit + 23
                        5   libExManCoreLib.dylib                   0x0065cbe9 OPENSSL_config + 153
                        6   libExManCoreLib.dylib                   0x002f0553 ADOBE_EXMAN::SSLInitializer::SSLInitializer() + 35
                        7   libExManCoreLib.dylib                   0x002f0527 ADOBE_EXMAN::SSLInitializer::SSLInitializer() + 23
                        8   libExManCoreLib.dylib                   0x002310cb ADOBE_EXMAN::CExtensionManager::CExtensionManager() + 747
                        9   libExManCoreLib.dylib                   0x00230dd7 ADOBE_EXMAN::CExtensionManager::CExtensionManager() + 23
                        10  libExManCoreLib.dylib                   0x00231bc0 ADOBE_EXMAN::CExtensionManager::getInstance() + 64
                        11  libExManCoreLib.dylib                   0x001e5d32 ExManInit + 82
                        12  com.adobe.ExtensionManager              0x00055f55 CInitCoreLibCommand::execute() + 579
                        13  com.adobe.ExtensionManager              0x00052d6c CommandExecutor_Impl::run() + 144
                        14  com.adobe.ExtensionManager              0x00052c69 CommandExecutor_Impl::runHelper(void*) + 69
                        15  libsystem_c.dylib                       0x99fe35b7 _pthread_start + 344
                        16  libsystem_c.dylib                       0x99fcdd4e thread_start + 34
                        Thread 0 crashed with X86 Thread State (32-bit):
                          eax: 0x06f849e8  ebx: 0x063dee71  ecx: 0xbfffda64  edx: 0x00004b00
                          edi: 0x00000000  esi: 0x0709ac00  ebp: 0xbfffdaa8  esp: 0xbfffda4c
                           ss: 0x00000023  efl: 0x00210286  eip: 0x00000000   cs: 0x0000001b
                           ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
                          cr2: 0x00000000
                        Logical CPU: 0
                        Binary Images:
                            0x1000 -    0xd7ff7 +com.adobe.ExtensionManager (7.0.1.17 - 7.0.1.17) <674354AE-B7BA-3CB4-BD1E-CD94A19483BC> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/Adobe Extension Manager CC
                          0x125000 -   0x127fff +com.adobe.AdobeCrashReporter (7.0 - 7.0.1) <940AF5C8-23AA-3311-A69F-6FC43C80F05B> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/Ad obeCrashReporter
                          0x12d000 -   0x144fff +VulcanMessage4.dylib (4.0.0.101 - 4.0.0.101 © 2013 Adobe Systems, Inc. All rights reserved.) <110A0C05-61A2-ABE9-FCF8-99CD2DEE26C3> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/VulcanMessage4.dylib
                          0x166000 -   0x16dffb +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <97387687-C9B4-76C5-FD95-8D4419271592> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                          0x176000 -   0x1dbffb +com.adobe.adobe_caps (adobe_caps 7.0.0.21 - 7.0.0.21) <A3A3E3BA-98D5-34FD-A1CC-AF9999C3A1F6> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                          0x1e4000 -   0xbb1fff +libExManCoreLib.dylib (0) <D77E9315-9610-3DD3-A97E-A14F59A06873> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/libExManCoreLib.dylib
                        0x116f000 -  0x11befe3 +com.adobe.headlights.LogSessionFramework (2.1.2.1756) <783979BC-67DD-3702-BCCC-EA29C2828962> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                        0x11f2000 -  0x1223ff7 +com.adobe.pip (7.0.0.1768) <863344FC-040D-30CD-8D0C-22DE00F1C11B> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
                        0x122e000 -  0x1306fff +IMSLib.dylib (7.0.0.37 - 7.0.0.37) <9CC26669-4BB6-3082-B450-D98A49ED6911> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/IMSLib.dylib
                        0x13d7000 -  0x13e4ff3  com.apple.Librarian (1.1 - 1) <68F8F983-5F16-3BA5-BDA7-1A5451CC02BB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Libr arian
                        0x5fb2000 -  0x6006fef +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <FEA983C9-2221-4A47-D3E2-95DEA682B378> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                        0x6020000 -  0x6f68ff3 +com.adobe.ape.engine (3.4.0.29366 - 3.4.0.29366) <35BD8121-4596-CA6E-194B-FCE0D0635448> /Library/Application Support/Adobe/*/adbeapecore.framework/Libraries/adbeapeengine.bundle/ Contents/MacOS/adbeapeengine
                        0x7164000 -  0x720ffff  libcrypto.0.9.7.dylib (106) <041B3399-5033-3395-9A71-6693F3A33D94> /usr/lib/libcrypto.0.9.7.dylib
                        0x7565000 -  0x756afff  com.apple.audio.AppleHDAHALPlugIn (2.3.7 - 2.3.7fc4) <903097A8-3922-3BF8-8B82-8BD1D831F6E7> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
                        0x9540000 -  0x9595fe2  com.apple.DVCPROHDAudio (1.3.2 - 1.3.2) <A9248133-6EB0-2702-A9B8-71C67BE55FD4> /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPR OHDAudio
                        0x95b4000 -  0x9619fe0  com.apple.DVCPROHDMuxer (1.3.2 - 1.3.2) <C1AA540F-CEAD-77BA-1CD6-0D467B4F76FF> /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMux er
                        0x9ec8000 -  0x9f86ff3  ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated .dylib
                        0xa00b000 -  0xa019fff  libSimplifiedChineseConverter.dylib (61) <60899F9C-A79F-3BC2-855E-DC5C78B98FEB> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
                        0xa01d000 -  0xa02fffd  libTraditionalChineseConverter.dylib (61) <519CAA3F-715E-3CAE-B158-57EC95D916B1> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
                        0xb4aa000 -  0xba29fe7 +Webkit.dylib (1) <5E61F610-AA01-BA06-32C0-0460F80E6EF5> /Library/Application Support/Adobe/*/adbeapecore.framework/Versions/A/Libraries/Webkit.dyl ib
                        0x8fe66000 - 0x8fe98e57  dyld (210.2.3) <4D38DEED-9837-3202-B8E9-41272D01EA2C> /usr/lib/dyld
                        0x90007000 - 0x90062ff7  com.apple.AppleVAFramework (5.0.19 - 5.0.19) <3C43A555-0A22-3D7C-A3FB-CFADDDA43E9B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
                        0x90063000 - 0x9027afff  com.apple.CoreData (106.1 - 407.7) <EC4B8297-8E01-3778-A8A4-E8747F91109D> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                        0x9027b000 - 0x9027bfff  libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
                        0x9027c000 - 0x902beffb  com.apple.RemoteViewServices (2.0 - 80.6) <AE962502-4539-3893-A2EB-9D384652AEAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
                        0x902bf000 - 0x906a2fff  com.apple.HIToolbox (2.0 - 626.1) <ECC3F04F-C4B7-35BF-B10E-183B749DAB92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
                        0x906a3000 - 0x906c8ffb  com.apple.framework.familycontrols (4.1 - 410) <B1755756-BEA2-3205-ADAA-68FCC32E60BD> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
                        0x906c9000 - 0x906c9fff  com.apple.quartzframework (1.5 - 1.5) <9018BE5B-4070-320E-8091-6584CC17F798> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                        0x90722000 - 0x90729fff  liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
                        0x9072a000 - 0x90774ff7  com.apple.framework.CoreWLAN (3.3 - 330.15) <74C4B50F-7016-341F-8261-D379B8F0CC97> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                        0x90775000 - 0x907ddfe7  libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
                        0x90a79000 - 0x90a97ff3  com.apple.openscripting (1.3.6 - 148.3) <F3422C02-5ACB-343A-987B-A2D58EA2F5A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
                        0x90a98000 - 0x90cc8fff  com.apple.QuartzComposer (5.1 - 284) <4E8682B7-EBAE-3C40-ABDB-8705EC7952BD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
                        0x90d4c000 - 0x90d69fff  libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
                        0x90d6a000 - 0x90da0ffb  com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
                        0x90da1000 - 0x9142dff3  com.apple.CoreAUC (6.16.13 - 6.16.13) <3DCF4456-AF8D-3E87-B00C-C56055AF9B8E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
                        0x9142e000 - 0x9146dff7  com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                        0x9146e000 - 0x914b5ff7  com.apple.framework.CoreWiFi (1.3 - 130.13) <1961CC70-C00D-31DE-BAB5-A077538CD5CB> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                        0x914b6000 - 0x9156afff  com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                        0x9156b000 - 0x916e3ff5  com.apple.QuartzCore (1.8 - 304.3) <F2EFC117-CDC6-3252-A4A8-880965764385> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                        0x916e4000 - 0x916fafff  com.apple.CFOpenDirectory (10.8 - 151.10) <CDA91E5D-6F99-3001-BD31-82585FCF5CA2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
                        0x916fb000 - 0x918b7ffd  libicucore.A.dylib (491.11.3) <FF55E176-7D66-3DBB-AF86-84744C47A02C> /usr/lib/libicucore.A.dylib
                        0x92139000 - 0x921aeff7  com.apple.ApplicationServices.ATS (332 - 341.1) <BEE998BC-E4A5-3BA0-A6B5-31A1DFA1522C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
                        0x921af000 - 0x9245dffb  com.apple.MediaToolbox (1.0 - 926.104) <DD264DFD-9AFB-38E2-A44C-B463DCB721A0> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToo lbox
                        0x9245e000 - 0x92489ff9  com.apple.framework.Apple80211 (8.4 - 840.22.1) <DBC31BEB-B771-315F-852D-66ADC3BD75A1> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/App le80211
                        0x9248b000 - 0x9249dfff  libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
                        0x9249e000 - 0x9270bffb  com.apple.imageKit (2.2 - 673) <CDB2AC11-6D60-34A7-83F9-F6E7DA25F97B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
                        0x9270c000 - 0x92731ff7  com.apple.quartzfilters (1.8.0 - 1.7.0) <F6A88D89-AB4A-3217-9D65-C2C259B5F09B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
                        0x92732000 - 0x9273cfff  libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
                        0x9273d000 - 0x927b7ff7  com.apple.securityfoundation (6.0 - 55115.4) <4843FAEA-8161-34B3-A1F1-720154884E34> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
                        0x927b8000 - 0x927b9fff  libsystem_sandbox.dylib (220.3) <C532F6A6-7E85-38F3-8660-EC1066DF67BE> /usr/lib/system/libsystem_sandbox.dylib
                        0x927ba000 - 0x927c6ffe  libkxld.dylib (2050.24.15) <BEC097B0-9D9A-3484-99DB-0F537E71963E> /usr/lib/system/libkxld.dylib
                        0x927d5000 - 0x9282ffff  com.apple.Symbolication (1.3 - 93) <227F64A9-FC28-3680-BE92-FFAE86FD4866> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
                        0x92830000 - 0x92a18ffb  com.apple.CoreFoundation (6.8 - 744.19) <DDD3AA21-5B5F-3D8F-B137-AD95FCA89064> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
                        0x92ab7000 - 0x92ae6ff7  com.apple.securityinterface (6.0 - 55024.4) <7C5E28DC-F8BE-3238-883F-E1646A2AF895> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
                        0x92ae7000 - 0x92af1ffe  com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/Ser viceManagement
                        0x92af2000 - 0x92af4fff  libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
                        0x92af5000 - 0x92af6fff  libquarantine.dylib (52.1) <094A1501-373E-3397-B632-8F7C5AC8EFD5> /usr/lib/system/libquarantine.dylib
                        0x92af7000 - 0x92b1cff7  com.apple.CoreVideo (1.8 - 99.4) <A26DE896-32E0-3D5E-BA89-02AD23FA96B3> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                        0x92b7b000 - 0x92b7eff3  com.apple.AppleSystemInfo (2.0 - 2) <4639D755-8A68-31C9-95C4-7E7F70C233FA> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/ A/AppleSystemInfo
                        0x92b7f000 - 0x92b86ffb  libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
                        0x92bee000 - 0x92c03fff  com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
                        0x92c04000 - 0x92c2dff7  libRIP.A.dylib (332) <521E60A6-A768-3CB8-B10D-D10EECD68A94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                        0x92c2e000 - 0x92c2efff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
                        0x92c2f000 - 0x92c37fff  libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
                        0x92c38000 - 0x92c3cfff  com.apple.IOSurface (86.0.4 - 86.0.4) <6431ACB6-561B-314F-9A2A-FAC1578FCC86> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                        0x92c3d000 - 0x92c46ffd  com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
                        0x92c47000 - 0x92c73ff7  libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
                        0x92c74000 - 0x93830ff3  com.apple.AppKit (6.8 - 1187.39) <ACA24416-D910-39B8-9387-52A6C6A561F8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                        0x93831000 - 0x938acff3  com.apple.CorePDF (2.2 - 2.2) <5A52A1CF-4801-3E6C-BF6E-E5E75A8DBD8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
                        0x938ad000 - 0x93996ff7  libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
                        0x93997000 - 0x93a46ff7  com.apple.CoreText (260.0 - 275.16) <873ADCD9-D361-3753-A220-CDD289196AD8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                        0x93a47000 - 0x93aa1ffb  com.apple.AE (645.6 - 645.6) <44556FF7-A869-399A-AEBB-F4E9263D9152> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
                        0x93aa2000 - 0x93aa6fff  com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
                        0x93aa7000 - 0x93aa7fff  com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                        0x93aa8000 - 0x93aacffc  libGIF.dylib (850) <45CD8B8F-7324-3187-B01C-8E16C04F33FA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib GIF.dylib
                        0x93aad000 - 0x93b0ffff  libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
                        0x93b10000 - 0x93b1afff  com.apple.DisplayServicesFW (2.7.2 - 357) <76D33A58-C39E-398A-9597-389A9B1FE76D> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
                        0x93b1b000 - 0x93ba0ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
                        0x93ba1000 - 0x93c82fff  libcrypto.0.9.8.dylib (47.1) <E4820342-4F42-3DEB-90DB-DE5A66C5585E> /usr/lib/libcrypto.0.9.8.dylib
                        0x93c83000 - 0x9403bffa  libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
                        0x94048000 - 0x94056ff7  libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
                        0x94057000 - 0x94377ff3  com.apple.Foundation (6.8 - 945.18) <BDC56A93-45C5-3459-B307-65A1CCE702C5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                        0x9441a000 - 0x94471ff7  com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
                        0x94472000 - 0x944eeff3  com.apple.Metadata (10.7.0 - 707.11) <F9BB5BBE-69D0-3309-8280-2303EB1DC455> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
                        0x944ef000 - 0x9476bff7  com.apple.QuickTime (7.7.1 - 2599.31) <3839E1F3-7948-3E68-9AE1-A0CEE8C59212> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                        0x9477d000 - 0x9479dffd  com.apple.ChunkingLibrary (2.0 - 133.3) <FA45EAE8-BB10-3AEE-9FDC-C0C3A533FF48> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/ A/ChunkingLibrary
                        0x9479e000 - 0x9488fffc  libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
                        0x94890000 - 0x9489efff  com.apple.opengl (1.8.9 - 1.8.9) <1872D2CD-00A8-30D1-8ECC-B663F4E4C530> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                        0x9489f000 - 0x948a2ffc  libCoreVMClient.dylib (32.3) <35B63A60-DF0A-3FB3-ABB8-164B246A43CC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
                        0x948a3000 - 0x948f3ff7  com.apple.CoreMediaIO (308.0 - 4155.4) <E2FF59A9-3728-3D17-A1AD-84DC1BDA2146> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMedia IO
                        0x948f4000 - 0x94909fff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
                        0x9490a000 - 0x9491cff7  libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
                        0x9491d000 - 0x94965ff5  com.apple.opencl (2.2.19 - 2.2.19) <968DD067-49D0-3B71-A96B-B3579698D992> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                        0x94966000 - 0x949caff3  libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
                        0x949cb000 - 0x949ccffd  libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
                        0x949cf000 - 0x94ac3ff3  com.apple.QuickLookUIFramework (4.0 - 555.5) <5A62C87F-5F74-380B-8B86-8CE3D8788603> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
                        0x94ac4000 - 0x94ac4fff  com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                        0x94ac5000 - 0x94f07fff  com.apple.CoreGraphics (1.600.0 - 332) <67E70F21-A0F1-356F-90B7-4B90C468EE2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                        0x94f08000 - 0x94f61fff  com.apple.QuickLookFramework (4.0 - 555.5) <4E381B7B-7EB5-37FD-9BA7-517DB48D07A7> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                        0x94f9a000 - 0x94f9cffd  libCVMSPluginSupport.dylib (8.9.2) <D6D0BB75-42DA-3772-AB5E-CBD59B343393> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
                        0x94f9d000 - 0x9509bff7  libFontParser.dylib (84.6) <7D3EB3CC-527E-3A74-816A-59CAFD2260A4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
                        0x9509c000 - 0x950a5fff  com.apple.DiskArbitration (2.5.2 - 2.5.2) <89822A83-B450-3363-8E9C-9B80CB4450B1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
                        0x950a6000 - 0x95146ff7  com.apple.QD (3.42.1 - 285.1) <BAAC13D2-1312-33C0-A255-FAB1D314C324> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
                        0x95147000 - 0x9523fff9  libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
                        0x95240000 - 0x95240fff  libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
                        0x959dd000 - 0x959defff  libdnsinfo.dylib (453.19) <3B523729-84A8-3D0B-B58C-3FC185060E67> /usr/lib/system/libdnsinfo.dylib
                        0x959df000 - 0x95dfcfff  FaceCoreLight (2.4.1) <B12C8721-EFB3-30A2-9A1B-ABCDF5670764> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
                        0x95e29000 - 0x95e30ffe  com.apple.agl (3.2.1 - AGL-3.2.1) <F13F8669-5FC5-386C-9100-523D2BBF23CE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                        0x95e31000 - 0x95e35fff  com.apple.OpenDirectory (10.8 - 151.10) <B9244697-CB05-3BD3-80A7-D188B3747B03> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
                        0x95e87000 - 0x96147ff3  com.apple.security (7.0 - 55179.13) <000FD8E9-D070-326A-B386-51314360FD5C> /System/Library/Frameworks/Security.framework/Versions/A/Security
                        0x9614d000 - 0x963a6ff5  com.apple.JavaScriptCore (8536 - 8536.30) <24A2ACA7-6E51-30C6-B9AE-17A77E511735> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
                        0x963a7000 - 0x96408fff  com.apple.audio.CoreAudio (4.1.1 - 4.1.1) <A3B911DB-77DF-3037-A47A-634B08E5727D> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                        0x96409000 - 0x9640cff9  libCGXType.A.dylib (332) <07B59FCC-6229-37C2-9870-70A18E2C5598> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
                        0x9640d000 - 0x9640dffd  libOpenScriptingUtil.dylib (148.3) <87895E27-88E2-3249-8D0E-B17E76FB00C1> /usr/lib/libOpenScriptingUtil.dylib
                        0x9640e000 - 0x9640fffd  com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
                        0x96410000 - 0x966b3ff3  com.apple.CoreImage (8.4.0 - 1.0.1) <C25B9EEC-4824-3088-BC08-2EA516C0728C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
                        0x966b4000 - 0x96811ffb  com.apple.QTKit (7.7.1 - 2599.31) <B9AE5675-22B0-3AA9-903F-2195DA0B04F5> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                        0x968ca000 - 0x96924ff3  com.apple.ImageCaptureCore (5.0.4 - 5.0.4) <6313E06F-37FD-3606-BF2F-87D8598A9983> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
                        0x96958000 - 0x9697afff  libc++abi.dylib (26) <3AAA8D55-F5F6-362B-BA3C-CCAF0D3C8E27> /usr/lib/libc++abi.dylib
                        0x96982000 - 0x969e6ff7  com.apple.datadetectorscore (4.1 - 269.3) <C11C2014-298E-3E2B-9F5D-02CCD3CA4AB3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
                        0x969e7000 - 0x96af4ff3  com.apple.ImageIO.framework (3.2.1 - 850) <C964E877-660E-3482-ACF9-EC25DFEAF307> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                        0x96af5000 - 0x96b00fff  libcommonCrypto.dylib (60027) <8EE30FA5-AA8D-3FA6-AB0F-05DA8B0425D9> /usr/lib/system/libcommonCrypto.dylib
                        0x96b01000 - 0x96b0afff  com.apple.CommerceCore (1.0 - 26.1) <8C28115C-6EC1-316D-9237-F4FBCBB778C5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
                        0x96b0b000 - 0x96b59ff3  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <6E858B9F-337A-314E-88B7-24A274ACE568> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
                        0x96b5a000 - 0x96b5cffb  libRadiance.dylib (850) <83434287-A09E-3A3F-A1AC-085B563BA46D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib Radiance.dylib
                        0x96b5d000 - 0x96bc3fff  com.apple.print.framework.PrintCore (8.3 - 387.2) <0F7665F5-33F0-3661-9BE2-7DD2890E304B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
                        0x96bc4000 - 0x96c13ff6  libTIFF.dylib (850) <78E121A6-92A2-3120-883C-7AA3C2966F9C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib TIFF.dylib
                        0x96c14000 - 0x96d30ffb  com.apple.desktopservices (1.7.4 - 1.7.4) <782D711D-7930-324A-9015-686C2F86DBA3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
                        0x96d31000 - 0x96d88ff3  com.apple.HIServices (1.20 - 417) <30AA0F48-A397-339E-BC62-24620B2B35BC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
                        0x96d89000 - 0x96dadfff  libJPEG.dylib (850) <36FEAB05-86C5-33B9-9DE9-5FAD8AEBA15F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib JPEG.dylib
                        0x96ddf000 - 0x96eb3ff3  com.apple.backup.framework (1.4.3 - 1.4.3) <6EA22ED3-BA18-3A37-AE05-5D6FDA3F372F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                        0x96ef3000 - 0x96f10ff7  libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
                        0x96f57000 - 0x96f71ffc  libsystem_kernel.dylib (2050.24.15) <9E58DCC0-D5FF-37E1-AA7F-F2206719E138> /usr/lib/system/libsystem_kernel.dylib
                        0x96f72000 - 0x96f75ff7  com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                        0x96f76000 - 0x96f89ff9  com.apple.MultitouchSupport.framework (235.29 - 235.29) <451701B6-03CE-3F26-9FF0-92D8DA1467EE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
                        0x96f96000 - 0x970efffb  com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <8BF022FC-C38A-34AA-8469-D98294094659> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
                        0x973dd000 - 0x9746fffb  libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
                        0x97470000 - 0x9752eff3  com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
                        0x9752f000 - 0x9752fffd  com.apple.audio.units.AudioUnit (1.9 - 1.9) <F7638E43-F885-372E-9DAE-24D0C21AA66E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                        0x97556000 - 0x975eefff  com.apple.CoreServices.OSServices (557.6 - 557.6) <E1600639-3EEC-3DF8-BD40-747BB2117988> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
                        0x975ef000 - 0x97657ff7  com.apple.framework.IOKit (2.0.1 - 755.24.1) <70DE925B-51E8-3C65-8928-FB49FD823D94> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                        0x9769b000 - 0x97738ff7  com.apple.PDFKit (2.8.4 - 2.8.4) <639CF802-BE94-39C5-AC97-B5B42FF910C2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
                        0x97739000 - 0x97743fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
                        0x97784000 - 0x977b7fff  libssl.0.9.8.dylib (47.1) <1725A506-BD80-39D5-8EE8-78D2FBBE194C> /usr/lib/libssl.0.9.8.dylib
                        0x977b8000 - 0x977e5ffe  libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
                        0x978e8000 - 0x9791bffb  com.apple.GSS (3.0 - 2.0) <9566A96D-C296-3ABD-A12A-E274C81C0B25> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                        0x9791c000 - 0x97933fff  com.apple.GenerationalStorage (1.1 - 132.3) <DD0AA3DB-376D-37F3-AC5B-17AC9B9E0A63> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
                        0x97934000 - 0x97935fff  libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
                        0x97936000 - 0x97937fff  libremovefile.dylib (23.2) <9813B2DB-2374-3AA2-99B6-AA2E9897B249> /usr/lib/system/libremovefile.dylib
                        0x97938000 - 0x97938fff  com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
                        0x97939000 - 0x97950ff4  com.apple.CoreMediaAuthoring (2.1 - 914) <DE0D100E-96AA-3E85-AFB0-43832E9B4C54> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versio ns/A/CoreMediaAuthoring
                        0x97951000 - 0x97a5cff7  libJP2.dylib (850) <3FFCEFA6-317A-34AF-8D99-AEBB017543C5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib JP2.dylib
                        0x97a5d000 - 0x97a69ff7  com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
                        0x97a6a000 - 0x97bf3ff7  com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
                        0x97e66000 - 0x97eabff7  com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
                        0x97eac000 - 0x97ebbfff  libGL.dylib (8.9.2) <1082B9A5-9AA3-35D4-968B-3A3FE15B1ED7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
                        0x97ebc000 - 0x97f03ff3  com.apple.CoreMedia (1.0 - 926.104) <D0E3BE86-12ED-31BE-816F-E72D757A9F2F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                        0x97f04000 - 0x97f08ff7  libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
                        0x97f09000 - 0x97f25fff  libPng.dylib (850) <26AD967A-D55E-3C5A-A643-D9953136DE58> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib Png.dylib
                        0x97f26000 - 0x97fd0fff  com.apple.LaunchServices (539.9 - 539.9) <C0E0CFFF-3714-3467-87DA-4A6F0AF1953B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
                        0x97fd1000 - 0x97fd1fff  libSystem.B.dylib (169.3) <0A82D354-A1B4-3F3E-8C7E-5047C38D4668> /usr/lib/libSystem.B.dylib
                        0x97fd2000 - 0x9810dff7  libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
                        0x9811d000 - 0x9818cffb  com.apple.Heimdal (3.0 - 2.0) <964D9952-B0F2-34F6-8265-1823C0D5EAB8> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
                        0x9818d000 - 0x9819dff2  com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
                        0x9819e000 - 0x981e0fff  libauto.dylib (185.4) <3098A75E-438E-3F18-BAAC-CD8F1CC7C2F7> /usr/lib/libauto.dylib
                        0x981e1000 - 0x981e1fff  com.apple.Carbon (154 - 155) <17F1B675-E054-3D2C-900B-C9CE69F1FC31> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                        0x982b9000 - 0x982c7ff3  libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
                        0x99001000 - 0x99025fff  com.apple.PerformanceAnalysis (1.16 - 16) <18DE0F9F-1264-394D-AC56-6B2A1771DFBE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
                        0x99026000 - 0x99032ff8  libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
                        0x99033000 - 0x99041fff  libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
                        0x99083000 - 0x9908fffa  com.apple.CrashReporterSupport (10.8.3 - 418) <03BC564E-35FE-384E-87D6-6E0C55DF16E3> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Vers ions/A/CrashReporterSupport
                        0x99409000 - 0x99409fff  com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
                        0x9940a000 - 0x99465fff  com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
                        0x99466000 - 0x9947ffff  com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                        0x99480000 - 0x994bbfef  libGLImage.dylib (8.9.2) <9D41F71E-E927-3767-A856-55480E20E9D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
                        0x994bc000 - 0x994c9ff7  com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versio ns/A/AppleFSCompression
                        0x994ca000 - 0x995d7057  libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
                        0x995d8000 - 0x9966fff7  com.apple.ink.framework (10.8.2 - 150) <A9C3B735-7D5F-3D7D-AA70-2CC852D09CDE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
                        0x99670000 - 0x99671fff  liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
                        0x99783000 - 0x997acfff  libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
                        0x997ad000 - 0x997adfff  com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                        0x997ae000 - 0x997f0ff7  libcups.2.dylib (327.6) <D994A44F-CCDD-3D40-B732-79CB88F45908> /usr/lib/libcups.2.dylib
                        0x997f1000 - 0x9983dfff  libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
                        0x9983e000 - 0x99847ff9  com.apple.CommonAuth (3.0 - 2.0) <34C4768C-EF8D-3DBA-AFB7-09148C8672DB> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
                        0x99848000 - 0x9984ffff  libsystem_dnssd.dylib (379.38.1) <4F164CA8-4A4F-3B27-B88A-0926E2FEB7D4> /usr/lib/system/libsystem_dnssd.dylib
                        0x99850000 - 0x9985afff  libCSync.A.dylib (332) <86C5C84F-11EC-39C0-9FAC-A93FDEEC3117> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
                        0x99877000 - 0x998a8fff  com.apple.DictionaryServices (1.2 - 184.4) <A31BB2CE-6965-3610-8B11-EA26EC6D7EEA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
                        0x998a9000 - 0x998adffe  libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
                        0x998ae000 - 0x998b4fff  libGFXShared.dylib (8.9.2) <F3B0E66D-5C47-3A5A-A2CD-F0C58E8322C3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
                        0x998b5000 - 0x99cb1feb  com.apple.VideoToolbox (1.0 - 926.104) <4275B89E-F826-3F65-ACE1-89052A9CAC6B> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToo lbox
                        0x99cb2000 - 0x99cb9ff3  com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                        0x99cba000 - 0x99dd2ff7  com.apple.coreavchd (5.6.0 - 5600.4.16) <F024C78B-4FAA-38F1-A182-AD0A0A596CBE> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/Core AVCHD
                        0x99dd3000 - 0x99f06ff3  com.apple.MediaControlSender (1.7 - 170.20) <7B1AC317-AFDB-394F-8026-9561930E696B> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versio ns/A/MediaControlSender
                        0x99f48000 - 0x99f4bffc  libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
                        0x99f4c000 - 0x99f52fff  com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
                        0x99f53000 - 0x99f55fff  com.apple.securityhi (4.0 - 55002) <F95F4BF5-2290-3CC4-A37A-4852F0AE6FAE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
                        0x99f56000 - 0x99f9aff7  libGLU.dylib (8.9.2) <F33F6C73-7F89-3B5B-A50F-2AB57BBA314D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
                        0x99f9f000 - 0x99fccffb  com.apple.CoreServicesInternal (154.3 - 154.3) <A452602B-67CB-39C4-95EB-E59433C65774> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
                        0x99fcd000 - 0x9a08afeb  libsystem_c.dylib (825.26) <6E35A83F-1A5B-3AF9-8C6D-D7B57B25FB63> /usr/lib/system/libsystem_c.dylib
                        0x9a08b000 - 0x9a0aaff3  com.apple.Ubiquity (1.2 - 243.15) <E10A2937-D671-3D14-AF8D-BA25E601F458> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiqu ity
                        0x9a0ab000 - 0x9a0c8fff  libxpc.dylib (140.43) <C628073D-51A0-3541-A665-1121520508C6> /usr/lib/system/libxpc.dylib
                        0x9a0c9000 - 0x9a117ffb  libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
                        0x9a118000 - 0x9a41dff7  com.apple.CoreServices.CarbonCore (1037.6 - 1037.6) <4DB4B0C9-1377-3062-BE0E-CD3326ACDAF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
                        0x9a454000 - 0x9a5a2ff3  com.apple.CFNetwork (596.4.3 - 596.4.3) <547BD138-E902-35F0-B6EC-41DD06794B22> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                        0x9a5dd000 - 0x9a5e0ff7  libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
                        0x9a5e1000 - 0x9a5e4fff  com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
                        0x9a5e5000 - 0x9a680fff  com.apple.CoreSymbolication (3.0 - 117) <F705A8CD-A04A-3A84-970A-7B04BC05DA97> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
                        0xb0000000 - 0xb0013fff +com.adobe.ahclientframework (1.8.0.31 - 1.8.0.31) <356D51D4-F625-3570-9D90-8E934EF03FFC> /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                        0xba900000 - 0xba91cffd  libJapaneseConverter.dylib (61) <A3F2F55D-E491-3532-A8F6-8D3F2455704F> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                        0xbab00000 - 0xbab21ffc  libKoreanConverter.dylib (61) <39F6BEE7-AE54-3423-B920-2A3573BC9A1A> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                        External Modification Summary:
                          Calls made by other processes targeting this process:
                            task_for_pid: 2
                            thread_create: 0
                            thread_set_state: 0
                          Calls made by this process:
                            task_for_pid: 0
                            thread_create: 0
                            thread_set_state: 0
                          Calls made by all processes on this machine:
                            task_for_pid: 398
                            thread_create: 4
                            thread_set_state: 0
                        VM Region Summary:
                        ReadOnly portion of Libraries: Total=190.2M resident=91.0M(48%) swapped_out_or_unallocated=99.2M(52%)
                        Writable regions: Total=122.5M written=23.3M(19%) resident=42.7M(35%) swapped_out=0K(0%) unallocated=79.8M(65%)
                        REGION TYPE                      VIRTUAL
                        ATS (font support)                 32.1M
                        ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
                        CG backing stores                  3364K
                        CG shared images                   1184K
                        CoreServices                       2788K
                        MALLOC                             33.4M
                        MALLOC guard page                    48K
                        Memory tag=240                     24.0M
                        Memory tag=242                       12K
                        Memory tag=243                        4K
                        Memory tag=249                      192K
                        Memory tag=35                      4572K
                        Stack                              70.1M
                        VM_ALLOCATE                        17.3M
                        __DATA                             9600K
                        __DATA/__OBJC                       192K
                        __IMAGE                             528K
                        __IMPORT                              8K
                        __LINKEDIT                         38.2M
                        __OBJC                             2432K
                        __OBJC/__DATA                       100K
                        __PAGEZERO                            4K
                        __TEXT                            152.0M
                        __UNICODE                           544K
                        mapped file                        87.7M
                        shared memory                       308K
                        TOTAL                             480.0M
                        TOTAL, minus reserved VM space    480.0M
                        Model: MacBookPro5,2, BootROM MBP52.008E.B05, 2 processors, Intel Core 2 Duo, 2.8 GHz, 8 GB, SMC 1.42f4
                        Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
                        Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 512 MB
                        Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334248312D4346382020
                        Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334248312D4346382020
                        AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.106.98.100.17)
                        Bluetooth: Version 4.1.4f2 12041, 2 service, 18 devices, 1 incoming serial ports
                        Network Service: Ethernet, Ethernet, en0
                        Network Service: Wi-Fi, AirPort, en1
                        PCI Card: sppci_expresscard_name, sppci_ieee1394openhci, ExpressCard@7,0,0
                        Serial ATA Device: Crucial_CT960M500SSD1, 960.2 GB
                        Serial ATA Device: HL-DT-ST DVDRW  GS21N
                        USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0x24400000 / 3
                        USB Device: hub_device, apple_vendor_id, 0x9126, 0x24100000 / 2
                        USB Device: BUFFALO INC. USB-SATA Bridge, 0x0411  (Melco, Inc.), 0x00db, 0x24120000 / 9
                        USB Device: My Passport 0748, 0x1058  (Western Digital Technologies, Inc.), 0x0748, 0x24130000 / 8
                        USB Device: Datacolor Spyder4, 0x085c, 0x0400, 0x24110000 / 7
                        USB Device: Display Audio, apple_vendor_id, 0x1105, 0x24140000 / 6
                        USB Device: Apple LED Cinema Display, apple_vendor_id, 0x9226, 0x24160000 / 5
                        USB Device: Display iSight, apple_vendor_id, 0x8508, 0x24150000 / 4
                        USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0x26400000 / 3
                        USB Device: Apollo M250, 0x1bcf  (Sunplus Innovation Technology Inc.), 0x0c31, 0x26440000 / 7
                        USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0x26410000 / 6
                        USB Device: EPSON Scanner, 0x04b8  (Seiko Epson Corp.), 0x012a, 0x26413000 / 11
                        USB Device: Samsung S2 Portable, 0x04e8  (Samsung Electronics Co., Ltd.), 0x1f06, 0x26411000 / 10
                        USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0x26200000 / 2
                        USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0x26240000 / 5
                        USB Device: Logitech Camera, 0x046d  (Logitech Inc.), 0x0821, 0x26242000 / 9
                        USB Device: SDDR-189, 0x0781  (SanDisk Corporation), 0xb7bd, 0x26243000 / 8
                        USB Device: FreeAgent GoFlex, 0x0bc2  (Seagate LLC), 0x5021, 0x26230000 / 4
                        USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0237, 0x04600000 / 3
                        USB Device: IR Receiver, apple_vendor_id, 0x8242, 0x04500000 / 2
                        USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000 / 2
                        USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8217, 0x06110000 / 4
                        FireWire Device: My Book, WD, 800mbit_speed
                        D
                        • 9. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                          tenorphoto Level 1
                          Despite a long call to tech support and a promise that they would call back within 72 hours with a "fix" I have not heard from them with a resolution to this ongoing problem. I got excited this morning as extension Manager CC flagged n update on Creative Cloud under my admin accoount. I installed it BUT it has not fixed the issue for me.
                          Now Creative Cloud does not load properly in my non-admin user account, the Home page simply shows  a pale blue spinning cog wheel.
                          • 10. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                            shuo_yang Level 2
                            Hi tenorphoto,
                            Extension Manager is crashed before /Extension Manager CC/Log folder created. You can create this two folder manually, and then Create a file called 'ExManCoreLibLog.YES' to get the log.
                            It was a known issue that if Extension Manager crashed, it will hang and could not startup before restart OS.( as you said: the little white clock icon simply spins around for ages then finally when it stops it does not list any applications).Which means you have to restart your mac after Extension Manager crashed
                            But from your attached crash report. I suggest you uninstalling Extension Manager CC, remove ExMan.db in /Library/Application Support/Adobe/Extension Manager CC/Configuration/DB".And then restart your mac and reinstall Extension Manager CC. Something important, all installed extensions will not be shown in Extension Manager after you removed ExMan.db.
                            If crash issue still exist please let me know.
                            Shuolei
                            • 11. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                              tenorphoto Level 1
                              Hi Thanks for your reply.
                              I have manually created the folders you mention above BUT I do not know how to "create a file called 'ExManCoreLibLog.YES' in order to get the log. Please let me know how to create this file (what program do I need to create it in)
                              I uninstalled Extension Manager CC but could not remove the ExMan.db as the folder /Library/Application Support/Adobe/Extension Manager CC/Configuration/DB did not exist.
                              Since reinstalling Extension Manager CC the problem remains exactly the same as previously.
                              D
                              • 12. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                Carl Sun Level 4
                                You can copy any file to this folder and rename it to "ExManCoreLibLog.YES". Please make sure there is no hidden extension left. At default Mac doesn't show file extension. Please check it in "Get Info" dialog. Extension Manager only care whether this file exists regardless of its content.
                                • 13. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                  tenorphoto Level 1
                                  I have added this file to the folder in question. I have launched Extension Manager CC but it still fails to launch properly and I have to force quit it.
                                  What do you want me to do now?
                                  D
                                  • 14. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                    Carl Sun Level 4
                                    This file is only for log file generation. It is not intended to solve this problem. Please send the generated log file (*.log) in the folder to exman.beijing@gmail.com.
                                    • 15. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                      tenorphoto Level 1
                                      I have created the folder and files as detailed above but launching Extension Manager CC still displays the same issue but it does not generate any log files in the location nor does it change the file I copied there  so there is nothing for me to send you.
                                      • 16. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                        Carl Sun Level 4
                                        Please try to run Extension Manager CC with the highest privilege:
                                        1. Open Finder.
                                        2. Navigate to "Applications/Utilities".
                                        3. Double click "Terminal.app" to launch it.
                                        4. In the Terminal window, input the following command (including double quotation mark) then press "return" key.
                                        sudo "/Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/Adobe Extension Manager CC"
                                        5. Input super user password and press "return" key.
                                        If Extension Manager CC starts up correctly and Dreamweaver is listed, then close it and try to launch it as normal.
                                        • 17. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                          tenorphoto Level 1
                                          I cannot get past the password I get this message
                                          Password:
                                          dominicnatoli is not in the sudoers file.  This incident will be reported.
                                          DominicsMacBookPro:~ dominicnatoli$ "
                                          • 18. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                            tenorphoto Level 1
                                            I assume you mean run extension manager with the highest privilege to mean under my Admin Account - the problem does not exist under that account. The problem is that my non admin user account will not load Extension Manager CC or any of the extensions loaded into Dreamweaver CC under the Admin account.
                                            In any event I tried your suggestion above under my Admin user account and got this reply in terminal:
                                            AS you see Extension Manager has not loaded properly there either. If I reboot and try again I think it will probably load as once it "crashes" under any of the user accounts on my computer (thre are just the two - one admin and one non-admin) it will not load properly under teh admin account until I reboot.
                                            • 19. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                              tenorphoto Level 1
                                              OK So I rebooted and ran the Terminal command as requested under my Admin user account. It loaded BUT does not list any of the extensions I have already installed in Dreamweaver, see screenshot.
                                              The terminal response was as follows:
                                              Last login: Thu Sep  5 11:40:06 on console
                                              DominicsMacBookPro:~ dominicadmin$ sudo "/Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/Adobe Extension Manager CC"
                                              Password:
                                              Extension Manager is starting up...
                                              Extension Manager window becomes visible.
                                              Init ExManCoreLib finished in the C++ side.
                                              2013-09-05 11:42:08 : INFO  get service manager executable name
                                              2013-09-05 11:42:08.305 CEPServiceManager[403:707] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1403, name = 'com.adobe.csi.CSServiceManager.4'
                                              See /usr/include/servers/bootstrap_defs.h for the error codes.
                                              Extension Manager launch finished.
                                              2013-09-05 11:44:08.383 CEPServiceManager[425:707] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1403, name = 'com.adobe.csi.CSServiceManager.4'
                                              2013-09-05 11:44:28 : INFO  get service manager executable name
                                              2013-09-05 11:46:08 : ERROR vcfoundation::io::VCFileNotFound: connect(/tmp/com.adobe.csi.ctrl-CS7-root) failed <2: No such file or directory>
                                              Trace: 0   ServiceManager-Launcher.dylib       0x0c213af1 Invoke + 4305
                                              1   ServiceManager-Launcher.dylib       0x0c219228 Invoke + 26632
                                              2   ServiceManager-Launcher.dylib       0x0c21b844 Invoke + 36388
                                              3   ServiceManager-Launcher.dylib       0x0c21b29d Invoke + 34941
                                              4   ServiceManager-Launcher.dylib       0x0c21b4a2 Invoke + 35458
                                              5   ServiceManager-Launcher.dylib       0x0c21f94f Invoke + 53039
                                              6   ServiceManager-Launcher.dylib       0x0c21ec6c Invoke + 49740
                                              7   ServiceManager-Launcher.dylib       0x0c21e75f Invoke + 48447
                                              8   ServiceManager-Launcher.dylib       0x0c21fe72 Invoke + 54354
                                              9   ServiceManager-Launcher.dylib       0x0c21ffe6 Invoke + 54726
                                              10  ServiceManager-Launcher.dylib       0x0c21c871 Invoke + 40529
                                              11  ServiceManager-Launcher.dylib       0x0c21ca65 Invoke + 41029
                                              12  ServiceManager-Launcher.dylib       0x0c21caec Invoke + 41164
                                              13  ServiceManager-Launcher.dylib       0x0c21c2c2 Invoke + 39074
                                              14  ServiceManager-Launcher.dylib       0x0c21c28b Invoke + 39019
                                              15  ServiceManager-Launcher.dylib       0x0c20c339 IMSConnect + 2617
                                              16  ServiceManager-Launcher.dylib       0x0c20a712 DispatchEvent + 242
                                              17  VulcanMessage4.dylib                0x00137b56 _ZN4csxs10servicemgr4api414ServiceManager13DispatchEventESsRNS1_9EventDataE + 154
                                              18  VulcanMessage4.dylib                0x00142f21 _ZNK5adobe6vulcan4impl23VulcanMessageDispatcher4SendERKNS0_3api13VulcanMessageE + 267
                                              19  Adobe Extension Manager CC          0x0005e3cf _ZNK11ADOBE_EXMAN12CExManVulcan24sendExManReadyMsgToAgoraEiSsSs + 751
                                              20  Adobe Extension Manager CC          0x0005043d _ZN11Application15ExManAppIsReadyEv + 127
                                              21  Adobe Extension Manager CC          0x0005844f _ZL36__ApplicationClass__airExManAppReadyPN7MiniDOM6ObjectEjPKP13APEOpaqueAtom + 20
                                              22  Adobe Extension Manager CC          0x00011a1d _ZN7MiniDOML7_invokeEPFP13APEOpaqueAtomPNS_6ObjectEjPKS1_ES3_jS5_ + 75
                                              23  Adobe Extension Manager CC          0x00011fbd _ZN7MiniDOML7_invokeERKSsP13APEOpaqueAtomPNS_6ObjectEjPKS3_b + 994
                                              24  Adobe Extension Manager CC          0x000111ff _ZN7MiniDOML23APEObjectInvokeMethodCBEP16Opaque_APEPlayerPvS2_P13APEOpaqueAtomjPKS4_ + 80
                                              25  adbeapeengine                       0x05f46880 APXGetHostAPI + 24784
                                              26  ???                                 0x0bc22dc5 0x0 + 197275077
                                              27  ???                                 0x0a183be8 0x0 + 169360360
                                              28  adbeapeengine                       0x06714cbf SWFLPlayer_Initialize + 3390239
                                              29  ???                                 0x0a183d30 0x0 + 169360688
                                              30  adbeapeengine                       0x06714cbf SWFLPlayer_Initialize + 3390239
                                              31  ???                                 0x0bafed00 0x0 + 196078848
                                              2013-09-05 11:46:08.526 CEPServiceManager[432:707] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1403, name = 'com.adobe.csi.CSServiceManager.4'
                                              2013-09-05 11:46:31 : INFO  get service manager executable name
                                              2013-09-05 11:46:31.628 CEPServiceManager[437:707] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1403, name = 'com.adobe.csi.CSServiceManager.4'
                                              2013-09-05 11:46:54 : INFO  get service manager executable name
                                              2013-09-05 11:46:54.734 CEPServiceManager[439:707] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1403, name = 'com.adobe.csi.CSServiceManager.4'
                                              2013-09-05 11:47:17 : INFO  get service manager executable name
                                              2013-09-05 11:47:17.841 CEPServiceManager[444:707] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1403, name = 'com.adobe.csi.CSServiceManager.4'
                                              2013-09-05 11:47:40 : INFO  get service manager executable name
                                              2013-09-05 11:47:40.948 CEPServiceManager[446:707] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1403, name = 'com.adobe.csi.CSServiceManager.4'
                                              2013-09-05 11:48:04 : INFO  get service manager executable name
                                              2013-09-05 11:48:04.054 CEPServiceManager[448:707] *** CFMessagePort: bootstrap_register(): failed 1100 (0x44c) 'Permission denied', port = 0x1403, name = 'com.adobe.csi.CSServiceManager.4'
                                              2
                                              • 20. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                                Carl Sun Level 4
                                                I said running extension manager with the highest privilege doesn't  mean under your Admin Account. OS doesn't run applications with highest privilege unless you specified explicitly. In other words, That you are admin doesn't mean all applications you are running have highest privilege. This is why I ask you to use sudo.
                                                • 21. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                                  tenorphoto Level 1
                                                  OK I get that thank you for your explanation. I tried to run the command in terminal it seems however that I cannot run sudo in terminal under my non admin user account as it gives me the error that dominicnatoli is not a sudoer and that the matter will be reported.
                                                  I do appreciate your help, but am rather perplexed as to why this issue is happening. Please persist with me in trying to sort  this out.
                                                  D
                                                  • 22. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                                    shuo_yang Level 2
                                                    You check "Remove Preferences" when unstalling Extension Manager, so all your extensions are gone.
                                                    Can you tell me what heppend by following steps?
                                                    1. Uninstall and reinstalled Extension Mananger by admin user
                                                    2. Launch Extension Manager from admin user
                                                    3. Re-launch your computer and login nonadmin user
                                                    4. Launch Extension Manager from nonadmin user
                                                    What happens?
                                                    In addition, for most extensions, if you install it from user A it could not be seen from user B.
                                                    • 23. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                                      tenorphoto Level 1
                                                      Hi Shuo_yang, I did what you said and the problem remains the same. I launch Extension Manager CC under non admin user account and it just crashes, I then restart it and it simply gets a white clcok icon which spins forever and does not go further. If I open dreamweaver CC it loads but does not have teh extensions installed which were installed in the Admin user account. and as Extension Manger CC will not launch I cannot load any extensions into Dreamweaver CC in non admin user account.
                                                      I also did a disk permission repair and restart then uninstal both Dreamweaver CC, and extension Manager CC and restart, then reinstall both Extension Manager CC and Dreamweaver CC, then update both. But none of this helped to solve the issue.
                                                      Any clues?
                                                      D
                                                      • 24. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                                        tenorphoto Level 1
                                                        Trail has gone cold on this post. Still have the same problem guys. This is a known Extension Manager CC issue according to the Tech support people, but no fix on the horizon??  Please help.
                                                        D
                                                        • 25. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                                          shuo_yang Level 2
                                                          At first, it was a know issue that if Extension Manager crashed, you have to restart your computer, if not, Extension Manager will hang.
                                                          And it also works as expected that your cannot load any extensions into Dreamweaver CC in non admin user account, because your non admin account didn't install this extension. We should investigate why Extension Manager crashed on your no admin user account, do you agree with me?  Does your Extension Manager crashed at thread 0 every time? You can verify it from MAC OS crash report, and check if there is a line like "Thread 0 Crashed". Does your  Extension Manager crashed immediately after launched or wait for a while?
                                                          • 26. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                                            tenorphoto Level 1
                                                            Hi Shuo,
                                                            Yes Extension Manager CC crashes immediately on launch under non admin user account. It does not generate a crash report however, so I am not sure if displays "Thread 0 Crashed" each time it crashes. Once it has crashed if I try to relaunch it simply hangs and I get a whte clock icon which spins forever.
                                                            This issue remains ongoing with Extension Manager CC, irrespective of whether i launch it in Dreamweaver CC or Photoshop CC. It simply does not work on my non admin user account.
                                                            I am happy to investigate why it will not lainch on my non admin user account and that is what I have been trying to solve for weeks now, with no success at all. Am I the only one having these issues with Extension Manager CC on non admin user accooutns?
                                                            • 27. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
                                                              Yuanyuan Liu Level 1
                                                              Yes, we haven't encountered this issue before and can't reproduce this issue.  So we wish to get more information to solve the problem.
                                                              currently, you can launch "Extension Manager CC" with admin user account, right? could you install some extensions and send the logs to exman.beijing@gmail.com?
                                                              • 28. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
        tenorphoto Level 1
        Just to say that after hours and weeks of talking to tech support. This issue has resolved.
        • 29. Re: Extension Manager CC not loading under User account on Mac Mountain Lion
        Lee Ramsay Level 1
        For anyone coming across this issue in the future, the issue that I observed was the following:
        Executing Extension Manager CC (first run, without an admin user using it previously) as a non admin user causes two popup boxes for admin authentication, every time you'd launch. That's right, every time. So close and re-open, it'll ask you again.
        Strangely extension manager cs6 (which is also installed for me because of fireworks) does not behave the same.
        I have not tested first running it as an admin, but this is not a solution for me as I deploy this software using a modular workflow, without user intervention. It's not possible for an admin user to visit every machine and first run this app.
        The solution I used was to add the setuid bit to the following executable, within the Extension manager CC application:
        sudo chmod a+s "/Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/Resources/ExManEscalatedPrivilegeServer"
        Please note, this essentially allows anyone to run this application as root, which does present certain security risks. However supplying the admin credentials is allowing it exactly the same privilige, and I need it to work properly.
        Hope this helps someone else googling (like I did, when I experienced this issue).
