1. Re: How can I get "grave" full screen toggle button to work in Premiere Pro CC?
Ann Bens Aug 25, 2013 7:13 AM (in response to Angularian)Your keyboard should be set to American.
If you have a foreign keyboard the shortcut is set something else. (don't know which one)
2. Re: How can I get "grave" full screen toggle button to work in Premiere Pro CC?
Angularian Aug 25, 2013 7:38 AM (in response to Ann Bens)I don't really see why this is different since the grave key "`" is in the same position on both UK and USA keyboards. Also the "Premiere Pro" keyboard I bought specifically for UK Premiere Pro users clearly shows that same top left key "`" as "Toggle full screen". I appreciate that some other special character keys are in different places (the "@" key placement is always an annoyance) but the grave key is not one of them and to be honest if this were the issue I would have expected a Google search to have turned up more results. As it is I think the CC editiion is so new that most are using earlier versions.
3. Re: How can I get "grave" full screen toggle button to work in Premiere Pro CC?
Jim_Simon Aug 25, 2013 7:56 AM (in response to Angularian)Be sure you're shortcut settings are set to Default. I've seen cases where changing that disables certain shortcuts.
4. Re: How can I get "grave" full screen toggle button to work in Premiere Pro CC?
Angularian Aug 25, 2013 8:25 AM (in response to Jim_Simon)I didn't change them. When I go into Edit them they're set to "Adobe Premiere Pro Default". I did (just) try changing them to "Adobe Premiere Pro CS6" to see if that would change things, but alas it didnt.
5. Re: How can I get "grave" full screen toggle button to work in Premiere Pro CC?
Jim_Simon Aug 25, 2013 8:29 AM (in response to Angularian)OK. Did you check to see if the shortcut is set? Maybe it got erased somehow?
6. Re: How can I get "grave" full screen toggle button to work in Premiere Pro CC?
Angularian Aug 25, 2013 9:10 AM (in response to Angularian)OK. Think I've got it now thanks to looking at the short keys and searching for "Full Screen". The upper left key is "`" which looks like a grave - a slightly angled single quote. But when I look at the "Application" setting for Toggle full screen it is set to "'" - a "normal" single quote. Sure enough, if I hit the normal single quote key the toggle works.
I have not been anywhere near the hotkeys and can't imagine why anything would change it from a grave key to a single quote - especially as they look almost identical on the screen. I'm guessing that Adobe changed this (maybe only for international users?)
Anyway I now know how to toggle full screen, although it makes the "Premiere" keyboard with its big purple key for "Toggle full screen" redundant. Does make me wonder what the shortcut key of "'" or CTRL + "'" gives that I'm presumably missing since it appears to have been remapped.
7. Re: How can I get "grave" full screen toggle button to work in Premiere Pro CC?
Ann Bens Aug 25, 2013 9:58 AM (in response to Angularian)Grave: maximize or restore frame under cursor. This means if you hover over the Program Monitor it gives you just that. A full screen of the PM with all its controls.
The ctrl + grave gives you a real full screen (no controls)
