9 Replies Latest reply on Aug 27, 2013 5:36 PM by WilliamTael
    Premiere Pro CS6 and CC with bad quality and incorrect colors in output video
    WilliamTael Level 1
      Hi everyone!
      I'm frustrated with my results after exporting a video with Adobe Premiere Pro (both CS6 and CC).
      The color of the video output is slightly different to the original file (i've checked if it was a problem with my video player, but no, i've tested the video with WMP and others with no success).
      Also the video quality is a little bad compared to the original file (i even tried to use frame blending once).
      Notice that i'm not using any effects or anything alike, and i'm a begginer in video editing.
      These are the parameters from the original video (made by Media Info software):
      Format                               : MPEG-4
      Format profile                       : Base Media
      Codec ID                             : isom
      File size                            : 1.70 GiB
      Duration                             : 1h 35mn
      Overall bit rate mode                : Variable
      Overall bit rate                     : 2 540 Kbps
      Encoded date                         : UTC 2012-12-06 21:47:27
      Tagged date                          : UTC 2012-12-06 21:47:27
      Video
      Format                               : AVC
      Format/Info                          : Advanced Video Codec
      Format profile                       : High@L4.0
      Format settings, CABAC               : Yes
      Format settings, ReFrames            : 4 frames
      Codec ID                             : avc1
      Codec ID/Info                        : Advanced Video Coding
      Duration                             : 1h 35mn
      Bit rate                             : 2 246 Kbps
      Maximum bit rate                     : 33.7 Mbps
      Width                                : 1 920 pixels
      Height                               : 816 pixels
      Display aspect ratio                 : 2.35:1
      Frame rate mode                      : Constant
      Frame rate                           : 23.976 fps
      Color space                          : YUV
      Chroma subsampling                   : 4:2:0
      Bit depth                            : 8 bits
      Scan type                            : Progressive
      Bits/(Pixel*Frame)                   : 0.060
      Stream size                          : 1.50 GiB (88%)
      Title                                : Video
      Writing library                      : x264 core 128 r2216 198a7ea
      Encoding settings                    : cabac=1 / ref=3 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2246 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.60
      Tagged date                          : UTC 2012-12-06 21:48:02
      I'm exporting the video using almost the same parameters from the original file.
      Here's a screen shot of my settings in Premiere:
      As you can see in the printscreen, the settings only differ from the original file parameters in the bit rate (which i raised a little),
      the TV standard (which i have no ideia what it changes), the level of H.264 (which i raised from 4.0 to 4.1, 5.0 and 5.1), and the bit rate encoding (which i've tried using CBR, VBR 1, and VBR 2).
      Just for my curiosity...why these numbers in orange are so extensive? I mean, the original video is only 01:35:30:06 in final output (which is correct).
      Notice that i do not use key frame distance (as i don't know what it does).
      If i'm doing something wrong, please tell me.
