2 Replies Latest reply: Aug 15, 2014 9:10 AM by Jared Langdon RSS
    Incorrect process dependencies
    philipp.ni Community Member
      when I just wanted to remove an application, the workbench warned me that there is one application that has dependencies on it. Because I knew there shouldn't be any, I searched through the processes but found nothing. When I looked at the process_dependency files I saw that there is one process listing a subprocess of the other application, named invoke9.
      I went to the process in the editor two more times and even searched the .process xml file but there is no such subprocess.
      Is there a way to remove this dependency or let livecycle rebuild the dependencies or whatever? I learned from the past that editing xml files mostly result in corrupted processes the editor won't open anymore. In this case however it seems that livecycle just ignores the changes (I removed the dependency in the xml) and reverts the file.
      Thanks for your help!
      Regards,
      Philipp
