25 Replies Latest reply on Sep 3, 2015 7:41 AM by Peter Spier
    When creating a checkbox in the form field, I export to find a double check.
    allieg096 Level 1
      I am creating an interactive PDF where the user will check off certain boxes. I create these boxes using the form field pannel. When I export, I find two checkmarks on each box, one thick and one thin. They overlap in some areas. In Indesign, only the thicker check mark shows. When I select that via the direct selection tool and delete it. I export to see that only the thin check mark appears. However, the thin checkmark is not visible when editing in indesign, therefore I cannot edit its aperance or treatment.
      How do I make it so that only the thicker check mark apears. Also, why is this a default to have two checkmarks overlap?
      Thanks-
