IIS is expecting c:\Inetput\wwwroot\cfdocs, however cfdocs is not appearing under wwwroot. How can I fix this?
Jim
Hi Jim,
Could you please confirm if it is ColdFusion 9. Also did you creat the connector while installing the ColdFusion?
Priyank
This is Coldfusion 10 installation. Cannot view any .cfm pages. Uninstall and reinstall have not cured the issue.
The connector was created and the properties files indicate that they are created for IIS.
Jim
As a member of Adobe CF support staff, Priyank, surely you ought to know that the docs are no longer shipped for install with CF10?? (ref: https://bugbase.adobe.com/index.cfm?event=bug&id=3342688)
Also from your answer (and how it in no way relates to the question, but rather seems like you have cherry-picked some words you recognise as being on your script), I suspect you are responding from a first-line support script, rather than from any actual ColdFusion knowledge you possess? Is that a correct assessment?
Adam
Hi Adam,
Apologies, that i overlooked the bug# 3342688. I was expecting some detailed information from the customer to drill down further (whether that is the only issue over here). That is the reason, my post sounded more like scripted. My bad.
I should have checked the same before responding.
Regards,
Priyank
