0 Replies Latest reply on Aug 26, 2013 7:51 AM by AmandaCole1989
    Prompt to Spell Check Before Printing, Save and/or Close Document?
      I need to set up some sort of script to promt myself to spell check before I print, save and/or close a document. After scouring the internet, I have come up with a script that was designed to run on CS3 (I am currently running on CS6). I have included the script below for reference. At first, this script worked and now it does not. I also tried modifying it, however I know little about JavaScript.
      Any other options on how to promt for spell check before printing, saving, and or/closing would also be greatly appreciated! Thanks in advance!
      /* CheckSpelling.jsx
      Version 1
      This script is written to remind a user to spell-check the current document.
      Put this script into Startup scripts folder and restart InDesign if it's running. */
      #target indesign
      #targetengine "session"
      var myLastDoc;
      var myConfirm;
      var myCheckSpellEvList = app.menuActions.item("Check Spelling...").addEventListener("beforeInvoke", myCheckSpellHandler, false);
      var myBeforeCloseEvList = app.addEventListener("beforeClose", myBeforeCloseHandler, false);
      var myAfterCloseEvList = app.addEventListener("afterClose", myAfterCloseHandler, false);
      function myBeforeCloseHandler(myEvent){
         myConfirm = false;
         if (!eval(myEvent.parent.extractLabel("SpellingChecked")) && myEvent.parent.saved == true){
            myLastDoc = myEvent.parent.fullName;
            myConfirm = confirm("Do you want to check spelling now?", false, "You forgot to check spelling!");
      function myAfterCloseHandler(myEvent){
         if (!eval(myEvent.parent.extractLabel("SpellingChecked"))){
            if (myConfirm) {
               app.menuActions.item("Check Spelling...").invoke();
      function myCheckSpellHandler(myEvent){
         app.activeDocument.insertLabel("SpellingChecked", "true");
