I am using V7 of Captivate.
Is it possible have your presentation pause until user presses a defined key, such as "G" on the keyboard to initiate play?
HI there
There certainly is. If the presentation is paused, it's likely pausing with a Click Box or a Button. Just assign G as the shortcut. (Look in the properties panel where you assign the action, There, you will find a field labeled Shortcut. Click in the box and it will turn blue. Then press the G key to assign it.)
Cheers... Rick
Worked Great, must have missed it in the properties.
