1 Reply Latest reply on Aug 26, 2013 9:47 PM by bregent
    pb with mysql_query() i don't understand
    histoiremamie Level 1
      ! ) Warning: mysql_query() expects parameter 2 to be resource, object given in C:\wamp\www\Monsitefideles\creation.php on line 43
      Call Stack
      #TimeMemoryFunctionLocation
      10.0040154080{main}( )..\creation.php:0
      20.0210162504mysql_query ( )..\creation.php:43
      ( ! ) Warning: mysql_num_rows() expects parameter 1 to be resource, null given in C:\wamp\www\Monsitefideles\creation.php on line 46
      Call Stack
      20.0220162616mysql_num_rows ( )..\creation.php:46
      Rows don't exist The global Amount  total, 800 The global Amount , 800 all is working well the select the insert
      could you verify in the following code the error that i have made :
      <?php
      $Nom=$_POST['Nom'];
      $Prenom=$_POST['Prenom'];
      $Adresse=$_POST['Adresse'];
      $codepostal=$_POST['codepostal'];
      $Don=$_POST['Don'];
      $Ville=$_POST['Ville'];
      $Commentaires=$_POST['Commentaires'];
      $Montant=$_POST['Montant'];
      $Montant_tot=$_POST['Montant'];
      $pdo='0';
      // Connection au serveur
      try
          require_once('connection.php');
      catch(Exception $e) //en cas d'erreur
          //on annule la transation
          $connection->rollback();
          //on affiche un message d'erreur ainsi que les erreurs
          echo 'Tout ne s\'est pas bien passé, voir les erreurs ci-dessous<br />';
          echo 'Erreur : '.$e->getMessage().'<br />';
          echo 'N° : '.$e->getCode();
          //on arrête l'exécution s'il y a du code après
          exit();
      // Récupération des données //
      // $query = ("SELECT * FROM  fideles      " ); //
      $result = mysql_query ("SELECT * FROM fideles
                                        WHERE F_NOM = $Nom AND F_PRENOM =$Prenom",$connection);
      $num_rows = mysql_num_rows($result);
      echo "$num_rows Rows\n";
      if (($num_rows) <= 0)
         // no result found
      { echo "n existe pas";
      $MonSql="INSERT INTO fideles(F_NOM, F_PRENOM,F_ADRESSE, F_CD_POST, DON,F_comment,           F_VILLE,F_MONTANT,F_MONTANT_TOT) VALUES('','$Nom','$Prenom','$Adresse','$codepostal ','$Don','$Commentaires', '$Ville','$Montant','$Montant_tot')";
                $res=mysql_query($MonSql);
               printf("Montant total, $Montant_tot");
          printf("Montant total, $Montant");
          //si jusque là tout se passe bien on valide la transaction
                // $connection->commit(); //
          //on affiche un petit message de confirmation
          echo 'Tout s\'est bien passé.';
      // found a result //
         else
         echo "existe";
         // il y a des lignes, donc la requête à trouver qqch.
                           while( $enregistrement = $select->fetch() )
          // Affichage des enregistrements
                                echo '<h1>', $enregistrement->nom, ' ', $enregistrement->prenom, '</h1>';
                                      $connection->query( "UPDATE 'fideles' SET F_MONTANT_TOT = $Montant + F_MONTANT_TOT");
                                      $Montant_tot= "fideles.F_MONTANT_TOT";
      // on affiche le résultat
                                printf("Montant total update  $Montant_tot" );
      <p>Bonjour !</p>
      <p>Je sais comment tu t'appelles, hé hé. Tu t'appelles <?php echo $_POST['Prenom']; ?> ton montant total est:<?php echo "Montant_tot : $Montant_tot"; ?> !</p>
      printf("Nom, $Nom");
      <p>Si tu veux changer de prénom, <a href="index.php">clique ici</a> pour revenir à la page formulaire.php.</p>
      thanks for helping
      Rahel Serero
