1. Re: Recieving a message 'Photoshop CS5 has been stoped Working'
kglad Aug 27, 2013 4:30 AM (in response to Stunt Master)1 person found this helpfulone of those screenshots shows 1gb of memory. is that correct?
2. Re: Recieving a message 'Photoshop CS5 has been stoped Working'
JJMack Aug 27, 2013 7:07 AM (in response to Stunt Master)1 person found this helpfulAlso check you reliability log to see if you can find out what is failing in Photoshop. Also a 32 bit 1GB system is not the best machine to run Photoshop on...
3. Re: Recieving a message 'Photoshop CS5 has been stoped Working'
Stunt Master Aug 27, 2013 8:57 AM (in response to kglad)Yes, I have a 1 GB ram for my pc .In my friend's pc it runs . I came to know that PS from System Requirements for Photoshop from http://helpx.adobe.com/x-productkb/policy-pricing/system-requirements-photoshop.html#main_ Photoshop_CS5_system_requirements
4. Re: Recieving a message 'Photoshop CS5 has been stoped Working'
Stunt Master Aug 27, 2013 10:20 AM (in response to Stunt Master)If found problem like the image posted by JJMack .
How to check Reliability Monitor , if found problem what to do ? i got this when i took it
https://www.youtube.com/watch?v=9DCh-T1HMMs like this ? can click 'check for solution to all problems...' ?
5. Re: Recieving a message 'Photoshop CS5 has been stoped Working'
JJMack Aug 27, 2013 12:45 PM (in response to Stunt Master)1 person found this helpfulDouble click on more then one of the Photoshop.exe stopped working entries to see the details like I showed. The details may show what is failing. Like mine showed it was in Photoshop ScripUIflex module. Used by scripts with Dialogs a would guess. Check several of yours. See if its always the same failure. The one you show is in widows ntdll.dll part of windows. On my system there are two ntdll.dll one 32bit version and one 64bit version. What were you trying to do at the time of failure
Also doing a google search on faulting module ntdll.dll returned 59,200 hits I would not know which to begin with.
Adding Photoshop returned only 25,600 hits
6. Re: Recieving a message 'Photoshop CS5 has been stoped Working'
Chris CoxAug 27, 2013 4:00 PM (in response to Stunt Master)
1 person found this helpfulThe onOne message means that your onOne plugins are messed up -- disable them, and check with onOne for updates.
They are probably also the cause of your crashes.
7. Re: Recieving a message 'Photoshop CS5 has been stoped Working'
Stunt Master Aug 28, 2013 8:06 AM (in response to Chris Cox) -
8. Re: Recieving a message 'Photoshop CS5 has been stoped Working'
JJMack Aug 28, 2013 8:31 AM (in response to Stunt Master)Plug-ins get installes somwhere in CS5 Photoshop cs5 Plug-in tree or the additional tree you add into you Photoshop CS5 preferences. Look in your "C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-ins\" tree for onOne Plug-ins they may have their own folder. Remove or rename them to "name.8bf.disabled" then start Photoshop and test..
